07-08-2021, 11:58 PM | #1 |
Battle Tactician
453
Rep 306
HELP | Weird front axle noise when driving slowly and turning (video)
Here's a quick video of the noise, it happens when the car is moving forward or backwards very slowly with the steering wheel moderately to fully turned.
The noise started happening a while ago but seems to have gotten worse, some days it's not noticeable while other days it's very obvious. I tuned the car very recently so taking it to BMW is probably not an option as the warranty would be void for any drive train stuff. Any suggestions are appreciated. Last edited by DailyDownshift; 07-08-2021 at 11:58 PM.. Reason: clean up formatting of thread |
07-09-2021, 03:00 AM | #3 |
Battle Tactician
453
Rep 306
07-09-2021, 06:45 AM | #4 |
Rep 555
If you've had any front suspension work done (springs/struts/top hats) it could be the top mount bearing binding or the sprint not properly seated in the bearing, alternatively could be the strut pinch bolt installed incorrectly (must be installed with bolt head facing forward & nut goes on from rear), not torqued correctly or maybe even re-used (it's a single use bolt).
If front suspension is all stock think I've read of another known issue with front strut/hub noise where there is dealer fix, maybe someone else can help with this or you'll have to do a search of the forum. |
07-09-2021, 12:51 PM | #5 |
Rep 1,389
Sounds from description and video same as what I had. I'll find thread.
https://f87.bimmerpost.com/forums/sh....php?t=1819548 |
07-09-2021, 10:13 PM | #6 | |
Battle Tactician
453
Rep 306
07-09-2021, 10:16 PM | #7 | |
Battle Tactician
453
Rep 306
07-10-2021, 05:01 AM | #8 |
Rep 1,389
Yes, same noise. You get it if dry steering or going over bumps under 30mph yeah? Or normal low speed steering too. Not influenced by braking. Sounds like a metallic creaking sound. It'll just be a loosened.
Funny how multiple threads now cropping up as our cars age together...! |
07-11-2021, 02:19 AM | #9 | |
Battle Tactician
453
Rep 306
Tags |
bmw m2 |
