07-29-2021, 09:53 AM | #1 |
BMW obsessed
9604
Rep 10,891
IND | KW Suspensions F92 / F93 M8 Height Adjustable Spring Kit
*IN STOCK* For improved looks and more driving dynamics - in OEM quality. KW height adjustable spring kits are a great alternative to conventional lowering springs. You now longer have to be satisfied with a fixed lowering height. KW HAS systems allow you to adjust the vehicle ride height with the KW height adjuster even after the kit has been installed. Your vehicle does not only get a more dynamic look with the KW height adjustable spring kit, but also the steering behavior and response of the standard dampers becomes more agile. All driver assistance systems and comfort features of a factory adaptive or electronic suspension remain operational and work harmoniously with our vehicle specific spring set up. Setup – Sporty Harmonic Spring Rates KW uses high-quality springs made of chrome-silicon steel with spring rates designed specifically for each respective OE suspension damper and wheel load. KW's expertise and engineering ensure the spring rates will pair perfectly with the different damper characteristics of your factory adaptive electronic suspension. Along with the use of high quality materials and the included KW ride height adjustment mechanisms, our KW height adjustable spring kits always includes the vehicle-specific bump stops with dust protection system to protect your factory suspension against wear & tear caused by road grime and debris. Continuous Ride Height Adjustment Similar to a coilover suspension, the KW height adjustable springs allow a continuous adjustable ride height within a tested range, something not possible with conventional lowering springs. The dust protection elements and spring perches included in the delivery, when applicable, are always adjusted to the maximum technically possible lowering, typically limited by the factory dampers. With KW height adjustable springs, a sporty and harmonious driving behavior can be achieved without the driving dynamics of performance-oriented vehicles suffering. The Benchmark for Suspension As with all KW suspension products our engineers develop vehicle specific parameters and spring specifications which undergo comprehensive testing on the Nürburgring Nordschleife and in our KW 7-post Driving Dynamic Test Center. With a KW Height adjustable spring system coilover kit the driving experience is more dynamic and direct. The KW Suspensions F92 / F93 M8 Height Adjustable Spring Kit may be viewed at the following link to our online store: https://ind-distribution.com/product...ble-spring-kit Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
