07-30-2021, 06:36 PM | #1 |
Rep 1
spark plugs
so looking for some help here BMW SAYS TO CHANGE PLUGS at 50 ,000 miles which i think is ridiculous considering the cost of the car i have a 2018 with 63 k on it rides fine i have not done plugs yet
has any body pushed the limit to see when plugs really need to be changed .thanks |
07-31-2021, 01:04 PM | #3 |
Rep 458
In the UK, exchange for new spark plugs comes up at the 2nd service which, for my X1, was at 34k miles and completed 3 weeks ago. Probably false economy to leave it beyond manufacturers service schedules. I had several cars that needed new spark plugs at 12k miles, but that was a long time ago.
08-02-2021, 08:23 PM | #4 |
Rep 659
BMW service changed the spark plugs at around 25k miles. I thought it was too soon, but it was included with the 3-year warranty and services, so I didn't complain. I drive a 2017 X1 2.0i.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
08-06-2021, 11:53 PM | #5 | |
Rep 277
I think the longer you go without changing the plugs the more it will wear your ignition coils as they will need more energy to create a spark to jump a larger gap. Just my two cents though. I would change them at 25k. It's cheap maintenance and good peace of mind |
08-14-2021, 07:14 AM | #6 |
Rep 261
Spark plug change intervals are set by the makers' estimate of electrode wear...if the electrodes are allowed to wear too much, the "gap" is increased to the point where you may experience "missing" at higher RPM's. With the exotic metal electrodes and unleaded gas, the change intervals have increased dramatically over the years...used to be 10K miles/once a year back in the day...now up to 100K for some cars...I DIY so have done the platinum plugs at 50K miles...only plan on keeping vehicles for 100K miles or so...doing one plug change along with all fluids (except for brake fluid which I change religiously every two years) at the 1/2 way point gives me peace of mind.
08-14-2021, 08:56 PM | #7 |
Rep 313
If you do not think the spark plugs need changing, then by all means, do not change them.
In my opinion, they are cheap insurance compared to the cost of the car, even at dealer service prices. It is not worth it to me to squeeze 20-30K more miles. |
08-15-2021, 12:51 AM | #8 |
Rep 2,816
Drives: F33 430 and F39 M35i
Changed them on my F33 (B46) around 60k and it looked like it needed them. Wasn't expensive, maybe $50 for four plugs? plug 1,2,3 took like a few minutes each, plug 4 took awhile. Haven't looked at the setup with the x1/x2 yet. only at 16k.
09-15-2021, 08:26 PM | #10 |
The BMW Life
21
Rep 69
Spark plugs - Which Brand..?
Anybody have a spark plug brand they are using, that has been problem free for these B46 engines?
Denso, NGK, Bosch? I think BMW OEM are NGK. Cheers, |
09-16-2021, 01:22 PM | #11 |
Rep 659
Hi COUWK,
Yes, both Bosch and NGK are OEM providers of spark plugs for BMW. A.F.A.I.K., the X1 F48 uses spark plugs from Bosch but I think it could be different depending on the market. Taking a look at realoem (https://www.realoem.com/bmw/enUS/sho...diagId=12_1921), I found that X1 can use 2 spark plugs:
I have a related question, are NGK spark plugs better? The Iridium ones for example. Is it worth installing them?
09-16-2021, 01:32 PM | #12 | |
The BMW Life
21
Rep 69
Thanks for that, and yes, that's a good question..! I have just ordered the following: https://www.ngk.com/ngk-94201-silzkg...ium-spark-plug I will update this thread when i install them. Maybe in a couple weeks, as I'm waiting for a thin-walled 14mm, 1-point deep socket... Currently running OEM BMW plugs and at 97,200km. No misfires yet. Cheers, |
09-16-2021, 01:58 PM | #13 | |
Rep 659
Searching here and there, I found this pros vs. cons page: https://greengarageblog.org/13-advan...ium-spark-plug
All those benefits comparing with copper (regular) spark plugs. I think the big question is, are they better than OEM BMW spark plugs? Is it even noticeable in the X1? I think you will help us here in a few weeks, haha. Or maybe another user in the forum can help us too. Finally, I want to share with you a video I found on youtube on how to change the spark plugs, which might be helpful: Quote:
09-16-2021, 02:19 PM | #14 |
Rep 659
I also found them in Amazon, 4 units pack for $72: https://www.amazon.com/-/en/NGK-SILZ...dp/B07FQLPFLG/ . And just in case, a user confirms that it fits X1 F48.
About the socket, I know you already bought one, but for anyone else (including me, haha), it's a 12pt 14mm deep magnetic socket like this one: https://www.amazon.com/-/en/PANOVO-d...dp/B073PT5M2R/
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD Last edited by jrveron; 09-16-2021 at 05:18 PM.. Reason: writing error |
09-16-2021, 06:23 PM | #15 |
Rep 659
More info here. I'm attaching the procedure to replace the spark plugs from ISTA, just for reference.
Phillipb930.00 |
09-21-2021, 07:04 PM | #16 | |
The BMW Life
21
Rep 69
Thanks for the info. Good things to know for sure.
I've always used iridium plugs; specifically on my e36, e46, and have never had any issues (Denso plugs) ; cant say that there was noticeable performance, or fuel efficiency gains [read, i was younger and had different driving habits ] But seeing as my e36 has 645k on it, my e46 has 390k, they still run great... Looking to see how they perform in a turbo, 4-cyl setup... Cheers, Quote:
09-21-2021, 07:17 PM | #17 | |
The BMW Life
21
Rep 69
That one from Amazon.com looks like the one i got.
Got mine from here: (if you're in Canada) https://partsavatar.ca/ngk-usa-iridi...num-plug-94201 4-pieces with tax was 67.30$ CAD These do fit the B46 engine in these cars here in North America. Cheers, Quote:
09-21-2021, 07:24 PM | #18 | |
The BMW Life
21
Rep 69
Meant to add: that one's similar to mine.
In Canada, this set is not a bad deal: https://www.amazon.ca/ARES-11015-3-P...dp/B07ZPHTNV6/ I know amazon has a markup, but it's quick delivery. Cheers, Quote:
09-21-2021, 07:32 PM | #19 | |
The BMW Life
21
Rep 69
Awesome; interesting the plug boots are "coated with talc" I'm guessing they mean the outside of the tubes. I've always used a dab of dielectric grease on the tip of the spark plug to help lubricate and prevent any moisture from attacking the plug. Seeing as it's silicone based, it's compatible with these boots...? I've never had any issues in the 20+ years I've been servicing my vehicles. Good docs. Thanks, |
09-29-2021, 08:42 PM | #20 |
The BMW Life
21
Rep 69
So to update ; i replaced the spark plugs this past wknd.
...my immediate feeling was that the car drove smoother overall. (maybe some less engine hesitation) As for fuel economy, perhaps a slight improvement. Seeing as the old ones were the original OEM plugs, they were probably breaking down. It's only been about 600km, mostly highway. [QUOTE=jrveron;28041931] |
09-29-2021, 08:44 PM | #21 |
The BMW Life
21
Rep 69
....i meant to add
One thing which i did not do was adjust the plug gap. The factory sets them at 0.030" I've read in places that the gap should be set to 0.020" - 0.022" So I'm willing to give that a try; it's an easy adjustment. I'll update here once i do... Cheers, |
09-30-2021, 04:43 PM | #22 | |
Rep 659
Awesome! Thanks for the update.
Glad to hear it's running smoothly. I may give it a try as well =). Regarding the gap, AFAIK, 0.030" is the factory setup. What would you gain by changing it? I read in other BMW's forums that they got problems when the gap is not right. Quote:
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD Last edited by jrveron; 09-30-2021 at 04:43 PM.. Reason: quote |
COUWK21.00 |
