e92 88000 miles grinding from transmission tunnel
08-18-2021, 04:53 PM | #1 |
Rep 11
hi all hope your all doing good looking for a bit of aadvice
i have a very annoying granding, similar to pads which have gone metal to metal (just not as loud) which seems to be coming from around the gearbox/ armrest area the noise is best heard on quiet roads and only heard from 10-30mph anything after 30 road noise takes over anything under 10 is too slow however i have checked all obvious things (all brakes are brand new including handbrake shoes) (no stones caught in discs) (no headshields/ handbrake catching) ive read of this noise on forums before some say a diff solved it some say a gearbox some say propshaft bearing, all of which are expensive to just throw parts at, any ideas? |
08-23-2021, 06:47 PM | #4 |
Walking to fix my car
9
Rep 32
That's pretty much what happened with mine when the diff was starting to go. It progressively got worse over the course of a few thousand miles.
If it still makes a noise when you're coasting in neutral / clutch down then it's more likely the diff than the prop bearing. Again, it'll indicate the diff if the noise changes under acceleration |
09-04-2021, 03:20 AM | #5 |
Rep 11
sorry for not replying, i had forgotten my login
thanks for the ideas guys, i was starting to think the diff it makes a bit of a rumble when i rotate the back wheels while lifted but i had a few other e92's that made the same noise so assumed thats just how they sounded. think thatll be the next job once i find a the right one. |
11-03-2021, 05:07 PM | #6 |
Rep 11
hi guys incase anyone comes acrross this thread and has a similar noise i finally took it uo in the air and checked it properly, the grinding was coming from the output shaft bearing on the gearbox, however from what i have been told and researched the only option would be a replacement box as there is very limited parts
11-07-2021, 09:25 AM | #7 | |
Rep 828
