08-27-2021, 12:52 PM | #1 |
Rep 9
N55 oil cap leak ?
Need advice. I have a 2014 bmw 435. About 100 miles ago I've changed the oil cooler gasket with it change the filter and a new o ring for the oil cap. Oil seems to seep from the oil cap…. Should I replace the cap ?
08-27-2021, 01:19 PM | #2 |
Rep 6
I had this happen to me recently. Be careful! I was losing a lot of oil on long drives. Easy fix. Install new cap, top off the oil and your good to go! I did have to go to autozone and get the right size cap wrench.
2013 335i Alpine White 88k miles and going!
bm3 stage 1, jb4 (map 0), ER Downpipe, M Performance Exhaust, ER chargepipe, bms intake, Fuel-it Stage 2 LPFP, HR Sport Springs, 19" Morr FS77 M Performance Alcantara Steering Wheel |
08-27-2021, 06:01 PM | #4 |
Rep 9
08-27-2021, 06:03 PM | #5 |
Rep 9
Most likely the route I'm gonna take with this inconvenience
08-27-2021, 06:58 PM | #6 |
Rep 1,574
Did you use the OEM/Mann Oil Filter package for your car or another from the Auto parts store. Had a neighbor a couple of years ago use the STP package identified as correct for his 2014 335i. Leaked immediately around the filter cap. When we pulled it off, discovered the o-ring was not round, but oval in shape across the width, thereby not sealing. He filed a complaint with STP , but heard nothing
08-27-2021, 08:54 PM | #7 | |
Rep 9
08-28-2021, 04:04 PM | #8 |
Rep 1,574
The Mahle is just as good as the Mann. Check for nicks, cuts or partially crushed o-ring. By any chance did you use a tool like a slip wrench around the base of the cap to remove it? If so, it may be deformed. Just "spit-balling" here.
08-28-2021, 05:55 PM | #9 |
Rep 9
That's an accurate hypothesis. I actually did, but it's been seeping prior to my intervention
08-28-2021, 08:37 PM | #10 | |
Rep 550
I would get an oil filter cap and anything else you need from them. Have a great weekend!
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
