Car locked( manual lock does not work)
09-03-2021, 09:36 PM | #1 |
Rep 169
I’m locked out of my car and now it won’t unlock… I stopped driving like 2 weeks ago anddd i never got around to replacing the unlock part on the driver door actuator so it’s impossible to get in. The key fob is dead and it’s a non comfort access key.. I think i’m screwed lmfao
Please tell me i can charge my key in another E90??? |
09-03-2021, 09:44 PM | #2 |
Rep 875
Pretty sure you can pop the plastic off the key fob and put in a new battery since it's non comfort access. Might need to solder. Take it to any locksmith that deals with car keys and they'll know what to do.
09-03-2021, 10:07 PM | #3 |
e91Owner
425
Rep 1,129
Turning the key to the right twice on the driver's door unlocks all of them on my cars. So even if the actuator doesn't work, you might not be SOL.
Can you go in through the trunk? Never tried to charge a key in another car, but it might work particularly if someone has comfort access and doesn't use their key slot. You can replace the soldered-in battery in non-CA keys. Lots of posts/videos how to do it, but if the battery works fine, you could still just break open the case and "jump it" with another 3V battery. If you went that route, it'll destroy the case, but still be functional. The replacement cases are around $10 on Amazon. |
09-03-2021, 10:56 PM | #4 | |
Rep 169
09-03-2021, 11:59 PM | #5 |
e91Owner
425
Rep 1,129
You can just jump the key with a regular 3V battery to the +/- terminals after you disassemble it. If he battery is still good, it will charge once inserted in the car. If the battery is bad, then yes, you'll need to solder a new rechargeable battery in as it is not removeable.
Although, I'd try the unlock twice thing first with the key in the drivers door. |
09-04-2021, 01:11 PM | #6 | |
Rep 169
09-04-2021, 01:40 PM | #7 |
Rep 103
Ex BMW owner (2007 E93 325i, E36 325i & 328i from the 90's)
09-04-2021, 01:49 PM | #8 | |
Rep 169
09-04-2021, 04:32 PM | #9 | ||
e91Owner
425
Rep 1,129
09-04-2021, 04:58 PM | #10 |
Rep 169
I don’t have that and i just wanna go ahead and change it, i’m just going to bite the bullet and attempt to solder another battery since I already have a shell and just bought a small soldering iron.
09-04-2021, 06:39 PM | #11 |
Rep 4,089
How long has it been since the engine ran? Does your Trunk mechanical key work? Is your Car battery FLAT? What did you do inside the driver door to prevent mechanical key from working? WHAT did you disconnect? Have you considered a "Slim Jim" or if you've never used one, what would a Locksmith charge to come out and use one to open Driver door, if in fact he can detent door latch on your model?
Dealer could tell you if your Remote Key is sending Radio Signal. No sense spending time/money on new key if (1) car battery is Flat; (2) Aerial diversity is NOT working. Not sure what you mean "Lock cylinder is broken". Does Key fit into lock cylinder? Will key NOT turn once inserted? Does Lock cylinder turn but nothing happens? Sounds like a locksmith who specializes in auto door locks (mechanical) is what you need. Don't think you'll find one on this Forum. Certainly NOT me. George |
09-04-2021, 07:23 PM | #12 | |
Rep 169
Trunk mechanic key works, but alarm will activate, not sure if that’ll lock down the vehicle, No way to get through trunk which is hilarious LOL Car battery is new and is not dead. Lock cylinder turns with resistance like something is connected, but doesn’t open anything. Tried rolling windows down with key and turning it two times but did nothing. I replaced all door lock actuators so either somebody tried to steal something and jammed it or me replacing the actuator alone made it not functional. I watched a video and it said it’ll break if you just replace the actuator so I’m sure it’s just broken. I’m also sure the aerial diversity is fine because the key range gradually got short after I bought the car. I’m sure the locksmith is my only option but I just need a way to get in the car so I can 1. unscrew the cylinder so I won’t need the key to get in and 2. start the car to charge the key’s battery just in case it loses function. I also really need to get it unlocked before the center lock turns off if the car’s battery dies Last edited by yonversace; 09-04-2021 at 07:29 PM.. |
09-04-2021, 08:40 PM | #14 |
Rep 4,089
Just have the tools you need to access and disconnect Negative Battery Terminal (10mm socket) handy. How much noise can a Flat Battery make & for HOW LONG?
THEN, unlock the Boot & Disconnect battery (-) Terminal. Some models have rear seatback release in boot so you can get into vehicle that way. Check battery voltage at posts, and if <12.0V, charge battery with Negative Terminal disconnected, Negative Battery Charger Clamp on (-) Battery Post (so as NOT to damage IBS). IF that doesn't get you "Inside", then I would call a locksmith. He probably knows more, and charges LESS than Dealer. George |
09-04-2021, 09:10 PM | #15 |
e91Owner
425
Rep 1,129
It's easy. One thing to note... all the the replacement batteries all have this problem. They sit slightly higher than the original which can cause the contact of the buttons on the new case to not make the correct contact with the buttons on the circuit board. The way I fixed this was to clip the posts on the inside of the case with nail clippers until the circuit board laid flush. It's probably less than a mm that you have to trim. Prior to that I would have to press on the buttons very hard to get it to work properly.
09-04-2021, 09:11 PM | #16 | |
Rep 169
09-04-2021, 09:28 PM | #18 |
Rep 169
Really? maybe i was thinking about when the siren is unplugged while it’s on, idk.
But what really stopped me is people complaining about the replacement batteries falling apart or the car not starting at all after replacement… or the car not unlocking… Where did you buy your replacement batteries? I’m having trouble finding a 1:1 copy by Panasonic, some of the batteries aren’t held together by the little metal things on it very well. |
09-05-2021, 12:51 AM | #19 | |
e91Owner
425
Rep 1,129
The battery type is VL2020. This is an example of one that is exactly like the one in fob currently: https://www.amazon.com/dp/B09BK19D63...G5XAH4X2XN6QZK Below is what 99% of the replacement ones look like. Note the difference in the manner the connectors are attached. The broadening of the blades are what cause it to not sit as low on the board. https://www.amazon.com/dp/B082SW1H6S...UTF8&psc=1 Which ever ones you purchase, make sure the pins are offset 90 degrees. Some of the listings that come from a search of "VL2020 BMW battery" have pins that are offset 180 degrees. Those will not work. As far as people complaining that the car wouldn't start, I'm not sure what cause that since the battery can be completely dead and the car will still start. Although I did hear of some of the replacement fobs not fitting in the slot properly, I didn't have that problem on my e60 (my e91 has comfort access, so this was never a problem as it takes regular batteries) |
09-06-2021, 09:48 PM | #20 |
Rep 169
I might just throw a brick at the window instead LMFAO. The locksmiths said they cAn’T dO iT and the dealership is going to be astronomical i’m scared to call
09-06-2021, 11:42 PM | #21 |
Rep 4,324
A thin steel rod from Home Depot and something to pry up on the either the left or right door b pillar area to hold it open.
Bend the steel rod whichever way needed to reach and poke the center lock button. You’ll have to jump the battery and deal with the alarm if the battery is dead. I got locked out of my e90 once because the battery died and I didn’t have the metal key to open it. I had bought a used window ready to break it if I couldn’t get the car open. |
09-08-2021, 03:26 PM | #22 | |
Rep 169
What am I missing ? I jumped in through the boot before with the small battery pack now apparently i can’t wtf. |
