LCI inner halo not the same color
09-05-2021, 03:53 AM | #1 |
Rep 79
As stated, my inner passenger halo light is not the same as the other 3. It is a yellowish color compared to white. From what I know, the LCI cars don't have a bulb to change but there may be an issue with a module of some sort. There seem to be a few different ones but I am unsure of which one controls the halos. Its just driving me nuts. Any help would be appreciated.
09-05-2021, 09:45 AM | #3 |
e91Owner
425
Rep 1,130
09-05-2021, 10:21 AM | #5 |
e91Owner
425
Rep 1,130
They aren't a typical bulb, per se, instead called an LED light module. So it basically is a bulb, just a different style. LEDs typically don't yellow, so it may be the ring itself. The part number is 63117263051.
They are accessible from under the housing, IIRC. |
09-05-2021, 11:39 AM | #6 |
Rep 79
So I would have to remove the headlight assembly to access the module? It would be pricey but would it make more sense to buy an entire assembly since it will be out anyway?
09-05-2021, 12:42 PM | #7 |
Rep 79
I just looked and I can actually just remove the fender liner and get under the headlight and replace the module that way. I really dont want to shell out the money for a new assembly when this one works well otherwise.
09-05-2021, 07:23 PM | #8 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
I believe the halo housing is just yellowed over time, but it's odd that non of the others show it - it's definitely not the bulb unless someone literally put a yellow LED in there or something. Are the lenses yellowed, the exterior of the headlights?
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
09-05-2021, 11:34 PM | #9 |
Rep 79
Its def not the housing. It is very slightly hazy but not yellow at all. If it were the housing both rings would be affected. I have a 3M sanding restore kit if that were the problem. I plan on doing that in the near future anyway but it is definitely one of the modules. There is no bulb to change in the LCI models. My old 2007 had bulbs. Here is a high res picture so you can compare both sides. Almost identical in clarity.
09-06-2021, 12:12 AM | #10 |
e91Owner
425
Rep 1,130
The aftermarket LEDs are so much cheaper, so I would give those a shot. Worst case, you buy one on Amazon Prime for $20 and if it doesn't turn the halo white, you just return it for free, and you know it's a problem with the housing. Best case, your problem is fixed for $20.
09-06-2021, 11:06 AM | #11 | |
Rep 79
09-06-2021, 07:48 PM | #14 |
Rep 4,324
09-06-2021, 07:52 PM | #15 | |||
e91Owner
425
Rep 1,130
The fender liner takes only a minute to remove, so if you can get to it from there, that's definitely the way to go. |
09-06-2021, 09:23 PM | #16 | |
Rep 4,324
It’s at least 5 minutes IF you have the tools ready. Messing with headlights or pulling the front bumper off on this car is my least favorite thing about it. |
09-07-2021, 08:38 AM | #17 |
Rep 2,494
FWIW, I had a similar issue when my LED bulbs in my e90 got damaged. The light still worked just fine, but the color on that side of the car was different. Ended up just changing the bulbs.
09-07-2021, 03:02 PM | #18 |
Rep 79
I haven't seen a tutorial or DIY anywhere about removing an LCI coupe headlight. I know the bumper has to be partially removed to get access to the bolts near the grill. I would really like to do it that way so I can polish the lense while its out. I also looked a bit closer and there are 2 modules for each halo individually. The inner one may not be fully accessible because I see the headlight washer piston/shock thing right below it.
09-07-2021, 05:30 PM | #19 |
Rep 4,324
It’s the same removal process for all the e9x body.
You can do it with the car on the ground, but it’s much easier with the wheels removed. Headlight has 5 t30 bolts that hold it in. 2 on top that are visible. 2 near the grills for the headlight bracket. 1 on the rear outer corner for the headlight bracket that is annoying to get to. You need a t30 bit with a bit ratchet or remove the front half of the fender liner. |
09-19-2021, 01:34 PM | #20 |
Rep 79
I did get this fixed. After removing the light from the car and the housing, I changed the LED module out. The module I replaced was actually good. It turns out the halo ring itself had somehow gotten burned. It was brown and black right at the edge. What I had to do was using some 120 grit sandpaper, sand the burned bit of glass away. Once I did that, I used a metal pick tool to pick out any small remaining bits of brown specks to clear the glass tube end completely. I used compressed air and a vacuum to get all the glass dust and keep it from entering the housing. I then put the module back in place and now both sides are bright white. I just wonder how the halo got burned in the first place...
