Why do I have a CA key?
09-08-2021, 11:07 PM | #1 |
Robot
1694
Rep 2,193
My 330 doesn't have comfort access. I can't start the car without the key inserted in the dash, I don't have the bumps on the door handle, and the VIN decoders don't show the option on my car.
I dropped my key today and the battery cover popped off and a battery fell out. I thought only the CA keys have the removeable battery? I never noticed the opening on the back of the key fob before - my 325i keys don't have this. Was it possible that the key was replaced, and the dealer used a CA key instead? |
09-08-2021, 11:27 PM | #2 |
Rep 1,232
yes, sure seems like you have the CA key.
My 06 330i doesn't have CA and there is no compartment for battery on those keys. My 07 335i does have CA and there is a rear flap you can pop open and stick a CR 2032 or something like that in it. If I understand the theory correctly BMW knew non-CA cars always needed to have the key in the ignition so they just designed it with an internally rechargeable battery, but with CA cars I mean who is going to stick the key in the ignition when you don't really have to. |
09-09-2021, 12:21 AM | #3 |
Art Collector
2427
Rep 3,450
Interesting!
Too bad you weren’t planning to retrofit CA haha. I don’t know the exact process, but I seem to recall getting a CA key programmed is a big part.
09-09-2021, 01:50 AM | #4 |
Rep 4,324
Probably a replacement key from a lock smith.
Does it have the bmw logo on the back?
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black E91 328 M Sport-Alpine over Black-Alpine over Saddle brown. E93 335i-DINAN tuned. Alpine over Saddle brown |
3PedalJake2613.50 |
09-09-2021, 06:32 AM | #5 | |
Robot
1694
Rep 2,193
Now I need to look into getting a replacement from a dealer. I do need a second key anyway. I also want to get the other keys deactivated - how likey is it that a dealer would do this without touching anything else (don't want to lose any of my coding.) I know it's completely possible, just wondering how likely it is that they'll just do the keys and not touch anything else as a "courtesy." |
09-09-2021, 07:02 AM | #6 | |
Rep 3,921
Put the key in and start the engine Stop the engine Take the key out Start the car as normal, but without the key in the ignition ...continue as normal. You can lock the car and walk away, leaving the engine running. You can drive as normal like this. I'm not sure what the behaviour is if you stall though. |
09-09-2021, 11:14 AM | #7 | |
Rep 4,324
09-09-2021, 12:30 PM | #8 | |
Rep 1,232
Another thing to keep in mind is it doesn't take that long to recharge the battery either. My wife has the 2nd key for each of my cars on her keychain in case of emergency, she ends up driving the non-CA 330i once every 9-12 months and never has issues with dead batteries. She has gotten warnings about low battery but by the time she gets to her destination its got enough charge to stop the warnings from coming back. |
09-09-2021, 01:34 PM | #9 | |
Rep 3,921
09-12-2021, 10:29 AM | #10 |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
I just got a new fob for the 325i from BMW dealer because it only came with one. I bought a CA fob like you're describing on Ebay for $11, figured it was worth a try, I took it to the locksmith, he said he could program it to a non-CA car as long as it hadn't been updated. I'm unclear on exactly which update or when it was rolled out, trying to figure that out but mine has recent updates and he couldn't establish communication with his programmer. I gave up and coughed up $280 to the stealer, showed them the registration and ID and they had a working non-CA key there for me in 3 days. So apparently CA keys will work under certain conditions, just not making use of the CA features. Anyone with more insight into this appreciated.
09-14-2021, 12:36 PM | #11 | |
Robot
1694
Rep 2,193
09-14-2021, 01:15 PM | #12 |
Rep 4,324
I’ve also seen that on aftermarket keys, the casing separates with clips it has.
On OEM keys, they cannot be separated without needed glue to go back together. Some aftermarket keys have the bmw logo on the lock button and others don’t. The knockoffs feel the same as oem with age.
09-14-2021, 10:12 PM | #13 | |
Neo-Luddite
2614
Rep 1,401
Edit: Other than the battery door difference the $11 knockoff I got feels exactly like the OEM fob, only difference is the logo on front that I could have added for 29c. It *is* higher security tho, little chance of someone stealing your signal and making a key. Last edited by 3PedalJake; 09-14-2021 at 10:35 PM.. |
09-16-2021, 09:30 AM | #14 | |
Rep 244
Drives: 2006 330i Manual
There are also options on ebay for around $110 last time I checked. You do have to mail the CAS with the key, so no car for about a week.
I did it with my 330i and got a working key with no issues. Quote:
