How remove this fuel connector
09-12-2021, 11:07 AM | #1 |
Rep 79
Hello all,
Sorry, not sure if I am embedding the pic ok, i have a link too: https://1drv.ms/u/s!Ar6Sux1DCPvQmnOTcdpZwGmC-G4y I found a fuel leak (The little curvy brown line at red arrow). I want to try to seal it up somehow but even though I disconnected the battery some fuel keeps coming out of it because I can't remove the gray connector. Service manual says using only your fingers, press the gray connector towards the center and pull straight out. The gray connector doesn't seem to give at all when I press on it. What am I doing wrong? Also, any tips on sealing the crack would be appreciated. I think I've got some epoxy so I'm gonna go with that. Thank you! |
09-12-2021, 11:12 AM | #2 |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
Push both the line and the connector towards the center, they should both move then hold the gray ring in and the fuel line should pull out.
09-12-2021, 12:09 PM | #4 |
Rep 79
I can push the fuel line towards the gray ring about an eighth of an inch maybe a quarter. But the gray ring kinda wiggles around in place, doesnt really move other than that...
09-12-2021, 12:39 PM | #5 |
Rep 445
The ONLY safe way to fix that leak is to replace the part. That type of plastic is notoriously difficult to "glue" with any method other than thermal welding. Almost nothing will stick to it, so any attempt to repair it will be very short-lived.
StradaRedlands4998.50 |
09-12-2021, 12:44 PM | #6 |
Rep 79
I don't mind if my attempt to repair fails, I'll be no worse off but if it works it'll be great.
I can't get that gray ring off so I'm waiting around now, hoping the seepage will stop and I can try the repair. |
09-12-2021, 01:02 PM | #7 |
Rep 445
Your best bet, BY FAR, would be to remove the pump, dry it out, then use a soldering iron to heat-weld the crack. Many epoxies will not take well to exposure to fuel, and will NOT stick to that plastic. It might last a bit longer if you rough it up, to give it some "tooth" so the epoxy can adhere mechanically, but you are very unlikely to end up with a long-term fix. I'd be surprised if it lasted a few months, and fuel leaks are not to be toyed with.
09-12-2021, 01:38 PM | #8 |
Rep 79
Thank you Ray. Let's not debate. I agree with you to some degree. Please remember not everyone here is a mechanic, or has the money to hire someone to do repairs.
While the connector stays on, a minute amount of fuel flows back and seeps out the crack in the photo. The crack is tiny and the seepage is almost nonexistent but just enough to prevent me from applying a sealant. If I can get the connector off I should be ok. I'm obviously doing it wrong, but I don't know why it hasn't come off when I've wiggled it every which way. If anyone has any suggestions I would appreciate them, thanks! |
09-12-2021, 02:09 PM | #9 |
Rep 2,019
Agree That connector is a hit or miss annoying for sure when I changed my fuel pressure regulator.
First, have you depressurized by removing the fuel pump fuse and running car etc.? I think the gray part slides back and hose then pulls out
335i e92 TPC 19Ts
09-12-2021, 02:29 PM | #10 |
Rep 79
No, haven't done anything with the fuse. I disconnected the battery and there's only a gallon or so of gas in the tank.
09-12-2021, 02:33 PM | #11 |
Rep 46
I have seen that kind of connector have tangs on the inside that catch on a ridge around the end of the pipe.
Push the pipe into the connector so that the tangs are not bound up on the ridge, then there is a tool that slips in to open the tangs, then you can pull the pipe out. When the pipe is out, the tool comes out easily. Forgive me if I am wrong, but I recall the tool as being a Ford thing. Do a Google Search for FORD FUEL LINE DISCONNECT TOOL, here is an example from Harbor Freight (not a recommendation, just an example), https://www.harborfreight.com/fuel-l...RoCqYUQAvD_BwE |
09-12-2021, 02:59 PM | #13 |
Rep 2,019
Its not threaded. I have done this on a n54 335i
335i e92 TPC 19Ts
09-12-2021, 03:02 PM | #14 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
09-12-2021, 03:02 PM | #15 |
Rep 79
The service manual has the diagram which shows exactly what is in my picture, and you can see it says to just use your fingers; it's not threaded and has a little play no matter which way you move/turn it.
09-12-2021, 03:40 PM | #16 |
Rep 79
I can't get that thing off so I'm leaving it alone instead of using more force and breaking it. The miniscule seepage that has been occurring is even less now, so I think it's just a matter of time before the fuel stops running out and at that point I'll try the plastic sealant stuff I got. Thread closed, thanks everyone!
09-12-2021, 09:06 PM | #17 | |
Rep 6,968
That's what you need |
09-12-2021, 09:21 PM | #18 |
Rep 445
It is entirely possible the plastic piece INSIDE the gray piece, which is supposed to release the fingers that hold the tube in place, is broken. I've had that happen more than once. If so, it will likely be very difficult, if not impossible, to remove the hose without destroying the connector. On some, there is still room to use an external tool to release it, but the "flange" on the hose in the photo makes using those tools impossible. It appears to me if you can't get it to release, you'll have to cut the connector off, which means a new pump or sender (whatever is under there).
11-20-2022, 01:37 PM | #19 |
Rep 11
Yea fuck that connector. It's a MASSIVE pain in the ass.
I've gotten it off before but it took me an hour each time. And when it does come off...it just just decides it's ready. I need to get back to it cuz I think the fuel level float is tangled inside after replacement causing fuel level gauge issues, but I just can't get it again. Fucker |
11-21-2022, 04:29 PM | #20 |
Rep 2,529
Drives: 2011 328i Wagon
Got to love German plastic. I just had to replace one of the fuel pumps in my Mercedes wagon (it has three, because Mercedes) because the plastic top of it cracked all to Hell and lots of gas was seeping out - it's underwater when the tank is more than 1/4 full, to add to the fun.
Though to their credit, MB uses a fuel pipe connector that comes apart easily, you just squeeze a button on it and pull.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
