Just bought e90 with MHD tune but I have no experience tuning or modding.
09-13-2021, 02:48 PM | #1 |
Rep 43
Hello everyone! I just bought an 08 335xi 6 speed sedan. I am completely new to this forum and to the tuning world so please bear with me.
I bought the car as a project car as is. The car is definitely not stock. The previous owner said it has an MHD tune, bigger turbos, after market blowoff valve, after marker coil packs, vrsf charge pipe. Thats all the info he gave me, nothing else. I guess my question is where do i go from here to insure the car i just bought isnt 1. over boosting 2. which MHD tune its running and 3.how to mess with the MHD tune. Thank you everyone in advanced!!! Ill be posting pictures soon. |
09-13-2021, 02:56 PM | #2 |
I only ride park
492
Rep 385
Welcome to the forum and congratulations on your purchase.
You`ll need to buy a copy of MHD for yourself and a K+ dcan cable (something like that) - Unfortunately MHD lock the license to an email address so people that don`t think ahead cant pass the license on with the car. There may be other-ways but that's the easiest and correct way imo. |
platano_4life5.50 |
09-13-2021, 03:10 PM | #3 | |
Rep 43
Thank you for taking the time to respond! Like I said I've never had a car this modded and its a little over whelming. but Ill see about getting a license after I fix other little issues then. |
09-13-2021, 03:18 PM | #4 |
Rep 1,232
Hey Welcome and congrats on the new car,
Like mentioned above you will need to buy your own MHD license since we assume the previous selling didn't give you his email and login details. I would suggest you just purchase the super license, I made the mistake of buying modules individually and have paid much more than I would have if I had just bought the super one from the start. 1. Overboosting is usually accompanied by codes, normally troubleshooting stuff like this requires you to capture a log in MHD which you can upload to datazap.me and have the geniuses on here help you figure out where the problem could be. 2. This will be written in the log once you start logging. 3. what do you mean "mess with the MHD tune" you mean like change all the values manually to make it a custom tune or just flashing to a different off the shelf (OTS) tune? |
Chapperss492.00 platano_4life5.50 |
09-13-2021, 03:18 PM | #5 |
I only ride park
492
Rep 385
NP. Plenty of threads and topics on here. Have a search around, you`ll get loads of great info.
platano_4life5.50 |
09-13-2021, 03:40 PM | #6 | |
Rep 43
Well I just thought that maybe having more boost than factory would trigger a over boosting code. i was just worried about to much boost because the car supposedly have bigger turbos and an aftermarket blowoff valve. so I'm assuming the MHD license will tell me how much boost the car is receiving when I monitor? when I said "mess with the tune" I was referring to changing the stage or reverting back and forth between stock tune and MHD tune. Thank you for your response! |
09-13-2021, 03:51 PM | #8 | |
I only ride park
492
Rep 385
People do use MHD to essentialy load a custom tune but MHD stage 2+ is an off the shelf tune and would not work with after market bigger turbos. Did he tell you what fuel option it is set to so you know which gas(?) you should be getting? Stage 2+ has 6 different fuel types to choose from on the version 9 maps. If it drives and throws no codes you are, relatively, fine - Lookalikehuh advice was sound. |
platano_4life5.50 |
09-13-2021, 04:18 PM | #9 | |
Rep 43
Thank you I didn't know about the different fuel type options. He just wrote me back and told me the tune is set with 93. As far as the turbos go I must have misunderstood him, but I will verify tomorrow morning if the turbos are indeed stock. Also, I was looking at the MHD page for the wireless adapter and there are two options, the orange and the black one. would both work on my car? does it even matter which one I get? Again, thank you everyone for the help! |
Chapperss492.00 |
09-13-2021, 04:37 PM | #10 | |
I only ride park
492
Rep 385
platano_4life5.50 |
09-13-2021, 05:13 PM | #11 | |
Rep 43
Awesome thank you for the info. Is a K+Dcan cable simply a cable that goes from obd2 to usb or does it also have to be specifically advertised as a K+Dcan cable? Because I found loads of them that didn't say K+Dcan. |
09-13-2021, 05:27 PM | #12 | |
Rep 1,232
When you "tune" the car the "boost target" is changed from like 8 PSI stock to like 14-19PSI depending on the map you chose. As long as the car is very close to that new target you won't get any codes that will set for over or under boosting. If you do get codes for over or under boosting that usually signals there is an issue, commonly issues arise due to vacuum leak, faulty diverter valves/Blow off valves, loose connections in the turbo pipes, or wastegate issues on the turbos themselves. Not sure how available E85 is in your neck in the woods but I personally saw quite a bit of gains switching from crappy California 91 octane fuels to E50 mix. |
09-13-2021, 05:30 PM | #13 |
I only ride park
492
Rep 385
Has to be specifically a K+Dcan to do coding stuff dude!
Regular OBD2 cables will allow you to read a clear codes but not change maps or mess with other bits and bobs |
