09-16-2021, 02:25 PM | #1 |
Rep 568
BM3 Stage 2 93 Octane: Intermittent stumbling on part throttle
Hello everyone,
I know that the first response to this post will be "post logs," but I have so far been unable to capture this issue on a log. It is an intermittent part throttle stumble from the engine (vibration, lack of power and acceleration) which tends to occur at roughly 2,000-3,000 RPM at decent but not heavy throttle application. Light throttle application does not cause this. Of note, it has almost always occurred at highway speeds (70ish) and typically in 5th or 6th gear at these RPMs. I always get out of the throttle as soon as I feel it. Full throttle acceleration does not cause this issue except on one occasion. This has occurred over a range of ambient temperatures, from low 60's to mid 90's. My car is currently running the following relevant mods: Dinan intake, CSF intercooler, fabspeed sport cat, full Dinan exhuast. The car is fueled with CA 91 octane fuel and 8oz of boostane per tank. The car is running the stage 2 93 octane tune, although I have experience this same issue on the ACN91 stage 2 tune as well. Coincidentally, the car is scheduled to have the oil and spark plugs changed next week at the dealer. I will be asking the dealer to save me the spark plugs so I can look at them to see if there is any obvious damage that could be leading to the issue. Has anyone experienced this issue or have any idea what could be causing it? Any thoughts are appreciated. |
09-16-2021, 03:20 PM | #2 |
Rep 348
I think I wouldn’t be comfy running the 93 tune with 91+booster.
I have no data/knowledge to back that up, beyond a convo with the tuner at Bend Calibration that seems to be well respected. I’m running BM3 S293 on non-ethanol 95aki Chevron pump for safety margin, which tells you what a wuss I am with regards to these tunes. I think the plugs will help. Beyond that, have you checked to see if it’s throwing/logging any codes? Last chatter I saw referencing breakup or issues with tunes/driveability or startup there were codes involved that were referenced later on. |
CalAcacian553.00 VisualEcho6642.50 |
09-16-2021, 03:54 PM | #3 | |
Rep 568
No codes so far, so I am rather confused. |
09-16-2021, 06:42 PM | #4 |
Rep 3,703
Hope you get this sorted.
I don't have any tips other than any time I tried running the Race Gas maps they always worked better with actual race gas than putting enough Boostane in the tank to "achieve" the calculated required octane level. |
CalAcacian553.00 |
09-16-2021, 06:50 PM | #5 |
Rep 568
Thanks. I am always dubious of the claimed results octane boosters advertise. Unfortunately, the only nearby station that sold 100 octane has shut down. My only other option would be mixing with E85 which I do have relatively nearby.
09-16-2021, 07:29 PM | #6 | |
Rep 3,703
If you're still on the stock HPFP, just keep the mix below 30% and you should be fine. I wonder if the issue will resolve itself simply from the fuel switch. |
09-16-2021, 07:33 PM | #7 | ||
Rep 568
09-16-2021, 07:40 PM | #8 |
Rep 3,703
The math sounds right. Just add the E85 first b/c you'll only be able to put in 13gal of fuel on an empty tank b/c BMW keeps some reserve in the tank.
CalAcacian553.00 |
09-17-2021, 08:07 PM | #9 | |
Rep 995
Drives: 2024 M4 Comp X-Drive
2024 Dravit Grey M4 Competition X-Drive
09-17-2021, 08:15 PM | #10 | ||
Rep 568
09-18-2021, 07:10 AM | #11 |
Rep 4,145
Drives: '18 M2 6MT
People still use octane boosters? Wow.
Sorry you're having the issue bro, but I'd definitely stop with the octane boost and flash the 91 map back. In fact, I'd swap to the stock map to see if the issue happens there, as I'm feeling it's not the plugs. You've checked all your intercooler and charge pipe fittings? |
09-18-2021, 11:02 AM | #12 |
BimmerPost Supporting Vendor
24350
Rep 191,156
Datalog and send it to PTF
CalAcacian553.00 |
09-18-2021, 11:10 AM | #13 | |
Rep 568
Since I've switched to the E30 blend and tune the issue hasn't presented itself. I think the issue was with the octane rating leading to the engine detecting knock and killing timing, but I don't have logs to prove it. |
VisualEcho6642.50 |
09-18-2021, 05:43 PM | #14 | |
Rep 4,145
Drives: '18 M2 6MT
09-20-2021, 08:33 PM | #15 |
Rep 568
Well, looks like that solved it. Running the 93 tune on juiced up 91 just didn't work. But so far the car is completely happy on the E30 tune.
It's actually faster than before and hasn't broken up once. I'm going to take a look at the plugs when they get pulled out on Wednesday to see if the octane booster had fouled them at all. Either way, I expect with the oil change and new plugs the car should be very happy. |
ZM22827.50 Sundinisagod107.00 |
09-20-2021, 09:35 PM | #16 | |
Rep 3,703
CalAcacian553.00 |
