HELP I was testing and pulling fuses in my 2007 335i now my car won’t start!!!
09-17-2021, 11:44 PM | #1 |
Rep 8
I was testing and pulling fuses found that the blow motor fuse was blown and front cigarette liter fuse was blow! I also pulled a couple other fuses because they weren't testing on the multimeter but turned out to be okay they just didn't get power when ignition wasn't on. But after replacing the blown fuses I tried to start my car and there's power and you can hear the fuel pump priming when trying to start, but it won't even crank.[/IMG]
2007 e92 bmw 335i * my car started fine before I pulled fuses, after I realized it wouldn't start I tested every single fuse in the fuse box to make sure they weren't blown I don't know if I missed place one or am just not seeing something that's why I'm asking for help because it may be something simple I'm missing ! |
09-18-2021, 08:08 AM | #2 | |
Rep 423
Drives: 2007 E93 MT6
Are you sure you put the fuse's in the correct spots? The fuse box is in a difficult location to see/access, so you might have misplaced one. A lot of people forget this, but there is also a fuse box in your trunk next to the battery. The 100 amp starter motor fuse is back there. Depending on your E92 build month/year, its fuse F102. I don't know how it could have blown amidst all your other messing around in the fuse-box, but its worth double checking. If you really want to go to town checking fuses, there is also a fuse box in your engine compartment where the DME is (on the left, in the rear, passenger side) This site is your friend: https://fuse-box.info/bmw/bmw-3-seri...uses-and-relay
BMW: Doing Amazing(ly cheap) Things With Plastic (crap) Since the E90...
Zacaustin2.50 |
09-18-2021, 10:30 AM | #3 | ||
Rep 8
09-18-2021, 10:55 AM | #4 | |
Rep 4,088
Attached are two pages from Bentley Manual: Fuse Chart for Early 2007 Model, built BEFORE 3/1/2007. Someone has replaced LARGE ("Maxi") Fuses on lower right with 30- & 40-Amp fuses that SHOULD be 50-Amp. When you press START button WITHOUT pressing Brake/Clutch, does Instrument Cluster Light-up? Does Central Locking work? If NOT, then likely Fuse F51 has blown, as that is NOT the CORRECT Amp Rating. F51 is where the Green 30-Amp fuse on the top row of LARGE fuses is located. That SHOULD be 50-Amp. The Orange 40-Amp fuse on bottom row of Maxi fuses can be put in F51 socket to test. THAT Orange fuse is shown in your photo as being in F66 (Diesel Fuel Heater) slot -- NOT used on your model. See the attached ISTA ScreenPrints of the CAS Fuses, and F51 circuit & Location. Fuse AMP RATING MATTERS. I would suggest getting some 50-Amp fuses, and putting CORRECT Amp-rating in the "Maxi" fuse sockets per fuse chart. Check to see if your vehicle has had Blower Motor Harness recall performed, and if it has NOT, NOW would be a good time to get it done, while you have the Glovebox removed. George |
09-18-2021, 10:57 AM | #5 | ||
Rep 8
09-18-2021, 11:03 AM | #6 | |||
Rep 8
09-18-2021, 01:19 PM | #7 | ||||
Rep 8
You need to start by checking if your car is throwing any codes….Do you have a codereader? Ultimately, you should download ISTA to your Windows 10 laptop to run full diagnostics. Gbalthrop's comments are very helpful.[/QUOTE] Well while I was messing with my car the doors were probably open for 2 hours so maybe not enough power to attempt to turn over ? I'm trying to get someone to jump me now |
09-18-2021, 02:00 PM | #8 |
Rep 423
You mentioned in your OP that you "...tested every single fuse in the fuse box to make sure they weren't blown" - how did you test those? If you want to test the starter fuse in the trunk, I would suggest pulling it out and testing it with a multimeter.
09-18-2021, 02:58 PM | #9 |
Rep 4,088
If ANYONE finds a "Starter Fuse" on an E9x (or ANY car ;-) please post a photo.
The "Fusible Links" in the "Rear Power Distribution Panel" on top of the Battery do NOT affect the power to the Starter, which is direct from the Positive Battery Terminal, via the BST (Battery Safety Switch). If you have 12V+ at the Jumpstart Terminal under the Hood, the LARGE B+ Cable from the Battery is providing Voltage to the Starter (wired directly from the B+ Jumpstart Terminal). If you don't have a cheap Multimeter ($10 or less), PLEASE get one. You CANNOT CORRECTLY DIAGNOSE an electrical fault without one: https://www.harborfreight.com/7-func...g_q=multimeter https://www.amazon.com/Plusivo-Digit...s%2C157&sr=8-5 George |
Zacaustin2.50 |
09-18-2021, 03:11 PM | #10 | |
Rep 8
09-18-2021, 09:45 PM | #11 | |
Rep 423
Then why is the rear fuse F102 labeled "...B+ terminal (engine compartment) STARTER, battery..."? As an electrical component, the starter at some point is connected to a fuse, and probably a hefty one. In any case, this is all OBE since the cause turned out to be...dead battery. Ironic, since I just purchased a portable jumpstarter for a vehicle the other day.
09-19-2021, 12:29 PM | #12 | |
Rep 4,088
Starter Fuse "Snipe Hunt", Part 1
However, so we can ALL understand our vehicles better, I attach ISTA ScreenPrints of B+ supply to Starter Motor. You do NOT provide attribution to the SOURCE of your attachment to Post #2, but your reliance on it may be misplaced. You refer to "fuse F102", but there is NO identification in attachment of any such F102 in OP's BEFORE 3/1/2007 model. I don't see ANY location diagram or photo for F102 in 3/1/2007 & later models in your attachment to post #2. This is NOT intended as an attack on your ability to understand the B+ Supply system in E9x vehicles. It IS a suggestion that there are Misleading, Incorrect references "out there". Even Bentley Manual and ISTA have such MIS-info at times. If one simply applies proper CONCEPTS of electrical circuits, it should be OBVIOUS that a 100-Amp fuse would NOT be sufficient to supply Current to the Starter Motor, or to handle output from a "180-Amp" rated Alternator. Yet F102 is rated at 100-Amp. Why is the battery rated at 900 to 1,000 CA? See attached ISTA Diagram of Rear Fuse Holder (located in Power Distribution Panel over Battery). F102 (100-Amp) supplies power to X1984 which goes to the INBOARD Transfer Point in front of Battery, and then to the VVT supply in the E-box, at least on N51 & N52-Engined Models, with VVT. NOT sure WHAT that does on OP's N54. If you have any doubt about the fact that there is NO fuse or Fusible Link in the B+ supply to Jumpstart Terminal, Simply disconnect the ENTIRE Rear Power Distribution Panel from the (+) Battery Terminal as shown in attached Photo. Measure Voltage at Jumpstart Terminal. Then ask yourself: WHY did BMW install BST (Battery Safety Terminal) which is triggered by the MRS in a frontal collision? BTW, Bentley Manual contains the SAME description (erroneous?) of F102, but if you try to FOLLOW the circuit, it is NOT to Starter. Sometimes it takes TIME and ANALysis to get CORRECT information. If you believe ANYTHING stated above is INCORRECT, please advise. George |
09-19-2021, 01:18 PM | #13 |
Rep 423
Thank you for the detailed explanation, George. You provided great information that everyone can benefit from.
My source for the "F102" fuse suggestion was the following link, also posted earlier: https://fuse-box.info/bmw/bmw-3-seri...uses-and-relay It appears to have taken info from a BMW source, given the detailed diagram - but, of course, there is no was of confirming that. Or the reliability of pretty much anything on the internet. F102 appears to reside in #8/#9 on the diagram. Its still not clear to me what that fuse includes "Starter" in its description, but I don't really care at this point. Please understand that not everyone has ISTA, not everyone has experience using/understanding arcane wiring diagrams, and not everyone (me, included) understood that the starter motor drew more than 100 amps. We also do not know the exact build date of OP's 238xi. Your use of phrases like "...like it should be OBVIOUS...", an penchant for all caps does not help educate. The only people here who need to be "schooled" here are the occasional know-it-all-know-nothing assholes, and I am not one of them. If I am misconstruing your intent, then I regret that. This is why (to many of my staff's irritation), I don't use email or IM as much as I used to, and instead pick up the phone and call them when I need something.
09-19-2021, 02:59 PM | #14 | |
Rep 4,088
A Forum should NOT be a "Battle of Wits", either fully-armed or LESS so. I do NOT intend my posts to be ANYTHING other than my best attempt to interpret reputable sources, and to post what THEY show or state, and to ALSO post my OWN interpretation of those resources. My posts are often TL/DNR 'cuz I offer my "CONCEPTS" to see if anyone takes issue with them, or can suggest a BETTER Concept. I'm sure I make mistakes, and I also may appear (or actually be ;-) arrogant or unmindful of the way others interpret my posts. PLEASE do NOT hesitate to point out those occasions so I can clean up my act. In the meantime, my objective will be to try to encourage myself and OTHERS (perhaps you ;-) to identify the most reliable sources available, and to QUESTION what those sources present: i.e. THINK!/ LEARN! George |
09-19-2021, 04:30 PM | #15 | |
Rep 423
George, I've been reading your posts for a long time and you definitely have played a part in helping me figure out how to fix a range of things, so keep posting. And you do not come across as uninformed at all - I hope I did not give that impression. I think its maybe the all caps and how I read that, but if you say you are coming from a good place, I'll take your word on that. Awesome day for a drive with top down out here....
09-19-2021, 06:28 PM | #16 |
Rep 4,088
