My E90 has a strut brace as standard!
07-05-2005, 04:39 PM | #1 |
Rep 899
Drives: F90 M5
I popped the hood (bonnet) of my E90 325i today to show my mate the engine and he immediately pointed out the strut brace that connected the two suspension turrets. I'd never noticed that before! Sorry if everyone already knew this, but none of my previous 3 Series cars had a strut brace, and I thought it was pretty cool that an item that many people put on as an aftermarket mod was now present and correct as standard
07-05-2005, 07:22 PM | #4 |
Rep 722
I did notice it, and was very pleased myself. The brace is somewhat hidden from view, but you can see it if you are looking for it.
I'll bet the aftermarket will be somewhat disappointed that they won't be able to sell those to e90 owners! |
07-05-2005, 08:02 PM | #5 |
MAUI BUILT
486
Rep 7,781
Drives: 2006 330i MT
No matter...
The aftermarket will still make these products, i.e. strut tower brace. They will point out that OE is fine but x-brand is better, just like all other aftermarket products...and people(not all of course) will buy them.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
07-05-2005, 10:31 PM | #7 | |
Rep 722
07-06-2005, 04:03 AM | #8 |
Rep 239
Sorry it's not a great picture, but I've highlighted where the strut brace sits! It only mounts to one bolt on the suspension tower, and kinda disappears in the middle!
07-06-2005, 07:27 AM | #10 | |
Rep 2,232
Drives: 2016 M3
same here,even thou its standard I will most likely get one so that it can make my engine bay looks better
2016 M3
2016 Audi Q5 3.0T |
07-06-2005, 08:28 AM | #11 | |
Rep 2,099
Yes, BMW's is a cheapie but, it's better than nothing. |
07-06-2005, 09:45 AM | #12 | |
Rep 6,158
07-06-2005, 09:51 AM | #13 | |
Rep 1,002
As so often, aftermarket cares more about looks than function |
07-06-2005, 10:54 AM | #14 | |
Rep 2,099
07-06-2005, 11:03 AM | #15 | |
Rep 6,158
if you roll a sheet of paper into a tube, you can support a book. If you rolled it so tight that there was no airspace inthe center it couldn't support anything. it all has to do with moment of inertia, and the farther away you can get mass from the neutral axis the better. |
07-06-2005, 11:28 AM | #16 | |
Rep 436
07-06-2005, 11:34 AM | #17 |
Rep 6,158
The point is weight, sure you could make a solid tube that was stronger than a hollow one. but it would be HEAVIER, smaller in diameter but much heavier.
a solid tube is NOT the most efficient shape for making a stiff structure, why do you think bicycle frames are hollow?????? Why are roll cages in racecars hollow??? |
07-06-2005, 12:25 PM | #20 | |
Rep 370
Drives: E90 325xi
you're all/both right. solid is ultimately stronger than hollow (same diameter), but hollow is very advantageous because it weighs significantly less without sacrificing very much strength. You can remove a lot of the middle of a solid rod and still maintain almost all of the same strength... the differernce is almost insignificant --so choosing hollow over solid is a no-brainer. |
07-06-2005, 02:04 PM | #21 |
Rep 2,099
Well, I would like to thank both ward & xcalibr for this extraordinary piece of engineering trivia!
And also for saving me the trouble of ever listening to any aftermarket tuners that are trying to sell me a small-diameter, solid strut brace. |
07-06-2005, 02:43 PM | #22 |
Rep 327
If the objective of the brace is keep the end points from moving away from each other, a solid brace is efficient. It consumes the smallest space while providing good tensile strength. It is not so efficient in bending, twisting or compression (resisting the tendency of the end points to move towards each other). For these, hollow is good.
Now, what problem are we trying to solve with such braces?
1998 323is SP manual with all the goodies in ArktisSilber + 330i auto SP PP CW iDrive/Nav SatRadio Active Steering Arktis/Beige/Poplar |
