I’m not even sure where to start.. MHD trouble
09-22-2021, 12:45 AM | #1 |
///Kenney
118
Rep 796
Well back again with another problem. Long story short. Car is in recovery mode from MHD flash. It’s failing to flash maps. I can’t even get it to flash back to stock.. I’m concerned as I’ve had this issue happen before with COBB.. car ended up being stuck in recovery mode.. ecu got bricked. Took it dealer and they ended up frying everything.. ended up having to replace CAS and eeprom? According to my mechanic. Wondering if this is causing any issues still or my car is wrote locked still from the Cobb? Wouldn’t replacing that stuff unlock it? Or wouldn’t MHD detect that before even attempting a flash?
I’ just don’t know what to do…
2009 335i / sedan / silver & black / stock / 187's / sport and premium package - wife's ( purchased 09/01/2015 )
2006 330xi / sedan / black and saddle brown / sport, cold weather & premium / stock - mine! ( purchased 04/01/2014 ) |
09-22-2021, 12:55 AM | #2 |
///Kenney
118
Rep 796
The whole issue started with my old COBB v2 only flashing about 3-4% of a map before it would say failure to connect ( thought it was a bad card ) ordered a new one. Still same issue.
Had car towed to Bmw to have it flashed back tk “stock” had power and all when it arrived just didn’t start… was in recovery mode. Few days later they call me saying car is completely dead.. no power at all. I was like what… car had power when dropped it off.. anyways after some back and fourth between them and them telling me they wanted to start with replacing the “cas” for $1200 but wasn’t a gaurentee it would fix it. I ended up having it towed to another shop and they ended up replacing cas and EEPROM or something along those lines. Got the car started and running. For the most part it has been running decent other than a few small issues that arrised after getting it back like back windows are finicky ( they do work tho ) and the passenger front heated seats button works but it’ll auto turn its self off in like 10 seconds. So idk if it’s finicky electronics or somehow I’m doing something wrong… |
09-22-2021, 12:56 AM | #3 |
///Kenney
118
Rep 796
It’s been about 6 months since having those replaced and getting car back running. Just yesterday tried doing the MHD
Low voltage? 0? What does that mean? Car had power.. was hooked up to a 6 amp charger from ports under the hood Last edited by Kenneykickin; 09-22-2021 at 11:44 AM.. |
09-23-2021, 12:52 AM | #4 |
Rep 355
I wasn't able to flash with the charger on the posts under the hood. Directly hooked up to the battery worked.
10-02-2021, 06:07 PM | #5 |
///Kenney
118
Rep 796
10-02-2021, 06:51 PM | #6 | |
Rep 355
I did try flashing with a cable first, and it did not work. That's why I bought the dongle. |
