E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Europe (Continental) > bmw 318d brake upgrade
Reply
      09-23-2021, 04:45 AM   #1
GeorgeKLT
Romania
15
Drives: BMW E90 318D LCI
Hi all,
I went ahead and upgraded the front brakes(pads, rotors, calipers, carriers, disc protections) on my e90 318d prod. year 2009
from the 300mm x24mm stock discs now it has the same setup of a 335d namely 348mm x 30mm
Should I change the brake master cylinder as well, same questions applies to brake booster. Below you can see the only difference between the master cylinders.
stock brake master cylinder
cylinder bore 1 [mm]:22,20
cylinder bore 2 [mm]: 23,81
335d brake master cylinder
cylinder bore 2 [mm]: 25,40
For brake booster I was not able to find any technical details, so I was not able to see the difference except they have different Part Numbers.
Please let me know your thoughts, since only the front brakes have been upgraded would you leave it as it is or would you change brake master cylinder/brake booster and perform coding as well.
Thanks.
      11-03-2021, 02:59 AM   #2
allex29
Drives: BMW E91 M47
when you have a 1.8 and need the brakes from a 3.5...better have changed the distribution =))
      11-05-2021, 04:05 PM   #3
GeorgeKLT
Romania
15
that was the first thing replaced on the car
      11-05-2021, 04:18 PM   #4
david in germany
Drives: 118i, 335i and 328i
Leave the master cylinder as is but code the car with +spbr.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
Reply
e90post
