CDV delete-Do you actually need an adapter like BMS?
09-23-2021, 01:57 PM | #1 |
Rep 304
Like the title says, is there any reason to pay for the BMS or similar CDV delete adapter? It seems that you can just connect the lines together, so why bother spending the money on another part? Am I missing something?
09-23-2021, 03:10 PM | #3 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
Not really, Take the stock one out, punch out the restrictor and put in back in. Easy
09-23-2021, 06:14 PM | #5 |
Rep 43
Exactly the same way as I've done and don't have any ill effect.
09-23-2021, 09:36 PM | #7 |
Rep 432
The clutch delay valve is this little plastic orifice that restricts the flow of fluid to the slave cylinder. When the valve is removed so is the restriction. Under normal driving situations the removal of this delay valve was barely noticeable to me but if you drive hard or dump the clutch it seemed to allow harder/faster clutch grab.
09-23-2021, 09:38 PM | #8 | |
Rep 3,386
09-23-2021, 10:04 PM | #9 |
Rep 769
Not a placebo. I couldn't change gears properly in my wagon to save my life when I bought it.
Removed the clutch choke two weeks in and it made an indescribable improvement. Not suggesting it really matters if it's in there or not on an absolute basis, but my muscle memory just did not sync whatsoever with the car until I removed the choke. Also... don't bother buying anything. Just remove the hunk of plastic and plug the lines back together. Don't lose the wire spring clips.
Sometimes a bolt is just a bolt.
09-23-2021, 10:17 PM | #10 | |
Rep 3,386
09-24-2021, 04:53 AM | #11 |
Rep 304
Awesome. Saving myself a little bit then since I was planning on buying the BMS part. Had it in my head that I MUST be missing something because why else would someone produce a part like that.....
