Possible IBS Issue
09-24-2021, 03:26 PM | #1 |
Rep 2
Possible IBS Issue
So replaced my battery in my 2011 335i coupe about three weeks ago after I got the battery light on the dash and iDrive was indicating charging malfunction. Battery was old and I had just bought the car so I replaced it at a third party shop. They said they registered the battery after install and all was good. After a couple days the same error came up. I then automatically thought alternator. Had it checked at three different places and all three said the alternator was fine under a heavy load and still sending out about 14.2 volts. It seems when I drive at night and have the headlights on as well as cruise control and the A/C I get the error to come up again. I am thinking it is either an IBS issue and it needs to be swapped out or the voltage regulator. Anyone else experience this problem? I would rather change out the IBS instead of performing surgery on my alternator trying to swap out the voltage regulator.
09-24-2021, 03:47 PM | #2 | |
e91Owner
425
Rep 1,130
09-24-2021, 03:52 PM | #3 | |
Rep 2
09-24-2021, 11:25 PM | #4 |
Rep 4,102
Need THREE (3) Things to properly diagnose the issue:
1) All Fault Codes in DME Module Memory; 2) Freeze Frame Data related to those codes (which will be lost if codes are cleared); 3) You can read System Voltage (Alternator Charging as you Drive) using "Hidden Menu 9.00". Hidden Menu must be "Reset" every time you turn on ignition, so it's a bit of a pain, but safer than trying to read a Scan Tool as you drive, as System Voltage is displayed on the Instrument Cluster: https://www.carsaddiction.com/articl...er-hidden-menu George |
11-05-2021, 05:07 PM | #5 |
Rep 12
Hello- hoping you can help.
The dealer says my E90 328I XDRIVE has some fault codes associate w/ the IBS. wants $215/ hr for a further diagnostic dealer mssg- FOUND FAULTS STOED FOR IBS CABLE - RECOMMEND DIAG. how can i view fault codes? i do not have a scanner? |
11-05-2021, 06:29 PM | #6 | |
e91Owner
425
Rep 1,130
Otherwise you'll need access to a scanner. |
