Reasonably priced metal underbelly/skid plate
09-27-2021, 12:55 PM | #1 |
Rep 1,783
Does anyone know of a reasonably priced metal skid plate? Motion motor sport sells one for the e46 for $178.
Unfortunately they don't produce any for e90's. https://www.motionmotorsport.net/col...underpanel-kit
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
09-27-2021, 01:23 PM | #2 |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
I don't know of any that are priced that low, for twice that amount you could get a Turner aluminum pan, e1 who has it says it's great. https://www.turnermotorsport.com/p-5...milled-finish/
09-28-2021, 05:07 AM | #3 |
Rep 304
That turner piece looks nice. Have been considering it since the alignment ship decided to just bend away my replacement belly pan to do the alignment and now it won't ever sit properly.....Barely more money then an OEM replacement.
09-28-2021, 11:33 AM | #5 |
Rep 18,801
I have the Turner aluminum belly pan. It's worth the price. IMO. It's not too much more than the BMW OE plastic part. I installed in in March or April and now has a good 10,000 miles on it. I've done two oil changes since installing it. It looks as good as the day I put it on. I've hit a few big sticks and small branches, not a dent nor scratch.
The other version someone mentioned was just a prototype when I was looking for a non-plastic solution. I'm not sure if it is in production. IIRC it was not painted. The Turner model can be bought with black powder coat. Get it if you can part with the money. The plastic OE part eventually just gets damaged, I've replaced it 3 times. |
