Dinan Exhaust D660-9000 on E91?
09-28-2021, 03:00 PM | #1 |
Rep 5
Drives: 2011 E91 328i 6MT RWD
I have a lead on Dinan exhaust part D660-9000 that is supposedly for LCI E90 328i confirmed fitment. I believe that this would also fit and work on LCI E91 N52 but would be very much comforted if anyone with knowledge could confirm?
09-28-2021, 03:01 PM | #2 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
The oem exhaust on realoem is listed for both the E90 and E91 so Id assume so
caseyb_4159.50 |
09-28-2021, 03:03 PM | #3 |
Rep 5
09-28-2021, 08:33 PM | #4 |
Is it the shoes!?
3885
Rep 5,112
I've got the E90 Dinan exhaust on my E92. They have different part numbers but it fits like a glove. No idea what the difference is.
Great exhaust choice though. Dinan stuff is expensive but boy do they make a mean sounding exhaust that doesn't drone. It sounds like a BMW should. Next BMW I get I'm immediately putting on a Dinan exhaust. |
caseyb_4159.50 |
09-29-2021, 07:26 AM | #5 | |
Rep 1,364
IIRC for the 335s they had 3 options. E90, E90 M-sport (+0.5" length) and E92/E93 (+0.75" longer/0.25" longer than M-sport) |
Welcome to NBA Jam3884.50 |
09-29-2021, 02:14 PM | #7 |
Rep 1,364
I have a Dinan axle back and my father has PE mod. (now this is for N54) the dinan is quieter and has a deeper tone. PE mod is louder, a bit more rumble, bit more rasp and at higher end has a the more 6cyl sound to it. Both are enjoyable
Piano_Black4.50 |
11-23-2021, 05:45 PM | #8 |
Rep 5
I should probably come back with an update. It sounds real good, but the fitment is slightly off due to rear chassis bracing being different and the stock exhaust just being bent in to fit around things, initially some washers used to move the bracing down for clearance, having some brackets machined to make it a bit better of a look.
fazm616.50 |
