09-29-2021, 03:38 PM | #1 |
Rep 25
Engine Valve Cover Question
I'm at 100K miles and was going to replace the valve cover gasket. There is no indication of a leak I just want to do it as a preventative measure. From my understanding these valve covers get brittle over time.
My question is this, should I replace it both the gasket and valve cover, just the gasket, or leave it until it leaks? |
09-29-2021, 03:42 PM | #2 |
Rep 417
BMW tells you to change both.
I changed my leaking gasket only. I wouldn't do the job as preventive, but if you have time to do it, why not. The waterpump replacement should be preventive. Did you do your OFHG already? Planning to do it as preventive?
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
JonTheGreek7.50 |
09-29-2021, 04:21 PM | #3 |
Rep 248
Drives: 1989 325i & 2014 335i
I wouldn't change it unless its leaking since it's an annoying/time consuming job.
As I understand it, most places change the plastic valve cover since it can warp with age (heat cycles). Reusing a warped valve cover is likely to cause premature leaks, so shops recommend replacing the valve cover. I would rather just replace the $50 gasket every 20-40k miles instead of paying for a $700 valve cover to hopefully get 100k miles out of it. |
JonTheGreek7.50 |
09-29-2021, 10:08 PM | #4 |
Rep 7,622
I would also say don't do the VCG as preventative... I would wait until the VC leaks, then since you are over 100k, strongly consider doing the VC as well.
JonTheGreek7.50 1bad14-F3030.50 |
09-29-2021, 10:57 PM | #5 | |
@_sunbish
284
Rep 611
JonTheGreek7.50 |
09-30-2021, 11:44 AM | #6 | |
Rep 10,373
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-01-2021, 09:06 AM | #7 |
Rep 5,776
As others said, don't change it unless your bored, want to spend money and learn about the car. I changed my whole cover 2 months ago but it was leaking for probably a year...not an issue that really warrants immediate attention. That being said--I decided to do the whole cover because there is a filter inside that can fail and then you have to do the job again and there is a possibility of the cover being warped or having cracks so at least I know I'm all good with that.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
JonTheGreek7.50 |
10-01-2021, 10:33 AM | #8 | |
Rep 25
I have no idea if any of these components have been changed at all. I frequently detail the engine bay, about 1once a month or so, so I should be able to pick up on any leaks fairly quick. |
10-01-2021, 10:36 AM | #9 | |
Rep 25
10-01-2021, 10:37 AM | #10 |
Rep 25
10-01-2021, 11:53 AM | #12 | |
Rep 248
I think the valve cover warp is just from heat cycles over many years. I don't think this applies to the n55, but when I replace an m20/m30/m50/m54/etc valve cover gasket, I put a dab of adhesive (like Drei Bond 1209) on any gaps (timing chain cover to head or m20 rocker shaft plugs) or sharp turns in the gasket (half moons). |
JonTheGreek7.50 |
10-01-2021, 01:33 PM | #14 |
Rep 268
Remember though, the valve cover also contains the positive crankcase ventilation valve. These valves do fail and will cause heavy breathing amongst other running issues. At 100k I would be looking at changing the valve cover with the inbulit pcv valve as a serious piece of preventative maintenance.
10-01-2021, 03:54 PM | #17 | |
Rep 417
I would do it in 1 hour on other engine but not the N55. Way too many pieces to remove.
'16 M4 bone stock
jgoens3787.50 |
10-02-2021, 08:24 AM | #18 | |
Rep 5,776
Yeah, for how much time it takes and the risk of screwing something up, it's not worth trying to save a couple hundred bucks.
10-02-2021, 08:40 AM | #19 |
Rep 864
2 Days on N54
1 Hour --- Took me 2 days on my N54 . So if we all (most) agree to Change the VC and not just the Gasket -- what Brand -- OEM or Aftermarket?? . My current BMW VC was made by Mahle . . |
10-02-2021, 10:29 AM | #20 |
1297
Rep 3,536
oem cover for sure
10-02-2021, 11:52 AM | #21 |
Rep 779
Well IDK what you guys are doing wrong. Again, it is an extremely easy cover to take off. 1 hour, that's it. 2 triangle aprons, the v support, the coils, coil grounds, and the valvetronic connector. Cover comes straight up. No wiggling, no finagling. The N52 VCG is a major PITA having to deal with the valvetronic motor.
10-02-2021, 12:12 PM | #22 | |
Rep 10,373
