Tpms switch to FTM
10-01-2021, 05:25 PM | #1 |
Rep 358
Tpms switch to FTM
2009 bmw 328i. I got coded 6 months. I had my tires rotated and now my low pressure like is on. All the pressures are good. I tried to reset using the dash. That did not work. What am I missing?
10-01-2021, 05:33 PM | #2 |
Rep 4,330
if you are indeed using FTM, then you reset it and go drive. It can only be reset engine on and in park, then does the actual reset after it measures wheel speeds.
10-01-2021, 08:31 PM | #3 |
Rep 358
My car is stick. I reset in on the dash and drove and it's still red. Is it different from a manual car? I'm 100 perfect sure I got it coded. I had to pull fuses and it was off since January. Any reason why a rotation, oil change, and state inspection would trigger the light on?
10-02-2021, 10:12 AM | #4 |
Rep 4,330
I can't imagine it's different manual/auto.
It's just measuring wheel RPMs using the wheel speed sensors and comparing them to one another. I pulled the RDC module entirely when I deleted mine. |
10-02-2021, 10:09 PM | #6 |
Rep 2,529
Drives: 2011 328i Wagon
If you are coded for FTM, the module should not be there to be read.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
01-23-2022, 11:20 AM | #7 |
Rep 358
I’m still having this issue. Every time I get my tires rotated. I get the low tire light on. Than the guy to has to reprogram it. I feel like he is annoyed with me. He had me pull fuses when he remote tuned it. Can someone confirm that this is right? He had me remove fuse 27 and that’s all
01-24-2022, 04:48 AM | #10 |
Rep 1,893
F27 also supplies the CCC/CIC controller so if you have iDrive, pulling F27 is not a great solution.
In any case, just unplug the RDC module. The location of the module depends on the build date of your vehicle but the odds are it is behind a panel in your trunk. Otherwise, it's under the plastic shield under the battery box. |
StradaRedlands4998.50 |
01-24-2022, 08:45 AM | #11 |
Rep 4,330
I swap wheels and tires winter/summer and it doesn't even trigger the tire light.
none of my wheels have TPMS sensors in them. FTM won't trip on a tire rotation. Pull the RDC module. |
01-24-2022, 01:44 PM | #13 |
Art Collector
2427
Rep 3,450
Sure, why not.
Sounds like it won't make a difference either way because you don't have iDrive, but I'd still put it back.
01-25-2022, 02:29 AM | #16 |
Rep 5
same thing was happening to me, i reset and nothing.. the light kept coming up. took it to bmw specialist, he held it down for longer than i did and it was cleared to this day
01-25-2022, 02:32 AM | #17 |
Rep 5
give my suggestion a try, might sound stupid but I looked hella embarrassed when the tech cleared it in seconds. just hold the reset button in for a while and it should say initiating, that never came up for me
01-25-2022, 11:39 AM | #19 |
Rep 1,893
At this point I suspect the coding - do you know exactly what was done? If you have BMW standard tools (NCSExpert, INPA etc) and a DCAN cable I could walk you through re-coding or at least check to see what was done.
01-25-2022, 01:01 PM | #21 |
Rep 358
I did put the fuse back in and it doesn’t have the tpms reset. I’ve own the car 10 years and had it coded last year. Maybe I’ll pull the fuse and see if that does anything.
01-25-2022, 01:04 PM | #22 |
Rep 358
I do have all that. Last few times the guy dialed in and did a remote tune. I have no idea on what I’m looking at. He also coded to tell you when to shift for the best mpg and that doesn’t work either. Not a big deal but the big red flat time sign is annoying
