Side indicator wire problem
10-02-2021, 07:52 AM | #1 |
Rep 4
I have some issuse with my left side indicator not working!
It looked like the cable was bad at the connector so i fixed that but no. Now im stuck and have no idea where that blue/yellow cable runs and i cant find a wiring diagram anywhere! Mabye anyone here knows/have had the same problem. BMW E92 335i N55 |
10-02-2021, 11:27 AM | #3 | |
Rep 4,088
As the first diagram shows, the Blue/Yellow wire from Front-Left Repeater goes to Pin #44 of FRM Connector X14261 (X14261/44). Second diagram shows Location of FRM & X14261, & 3rd diagram shows Connector View of X14261. I would suggest using a Multimeter to determine IF you have voltage at X389/2 ("flashing") when Left signal active. Measure that voltage in reference to GOOD chassis Ground. THEN check "Continuity to Ground" at X389/1, Brown wire. First attachment shows location of Ground Point X165 under hood on Left side. Compare RF Repeater with similar wiring. Please let us know what you find, George |
Gisarz0.00 |
10-14-2021, 12:05 PM | #4 | ||
Rep 4
