10-04-2021, 12:34 PM | #1 |
Rep 96
N55 EWG e30 Custom Tune Dyno
Here's the results results of my custom e30 tune flashed via MHD
Mods: DP VRSF 7.5" FMIC DIY intake XHP stage 3 Stock fuel system All runs were done in 4th gear. Red run is the MHD stage 0 flash with e30 in the tank. +97 whp and +160 tq over stock Next up, fx180 ,n20 tmap, full e85. Last edited by WOT808; 10-04-2021 at 01:28 PM.. |
10-04-2021, 12:44 PM | #2 | |
Rep 187
Drives: BMW F36 435i FBO
10-04-2021, 12:55 PM | #3 |
Rep 96
Red is ots e20. Blue was one of my early revisions, was down on power up top because it was a little on the rich side. |
lucasborka41.00 AmuroRay2315.00 |
10-04-2021, 01:00 PM | #6 | |
Rep 187
10-04-2021, 01:18 PM | #7 |
Rep 4,173
So what is with the wonky power curve?
https://f87.bimmerpost.com/forums/sh....php?t=1862698 Peak horsepower made after HP/Torque crossover
Mods: Yes.
10-04-2021, 01:28 PM | #8 | |
Rep 96
I think an inlet would help me get a little more flow up top, my turbo is tapped out up there. |
10-04-2021, 01:31 PM | #9 | |
Rep 7,622
Datalogs from the runs? Looks like it makes barely more power than OTS map also |
10-04-2021, 02:22 PM | #11 | |
Rep 7,622
Also did you measure ethanol content? I'd be surprised if you didnt have HPFP dips/crashes with E30 at that boost level. |
10-04-2021, 03:04 PM | #12 |
Rep 4,173
10-04-2021, 03:13 PM | #13 |
Rep 96
10-04-2021, 03:33 PM | #15 | |
Rep 96
10-04-2021, 04:36 PM | #16 | |
Rep 4,173
Also, as requested: https://www.2addicts.com/forums/show....php?t=1595298 Here is a PWG for comparison https://f30.bimmerpost.com/forums/sh....php?t=1312822
Mods: Yes.
10-04-2021, 04:44 PM | #17 |
Rep 4,173
Mods: Yes.
10-04-2021, 04:45 PM | #18 | |
Rep 96
I don't like boost/load actual to ride target. |
10-04-2021, 04:50 PM | #19 | |
Rep 7,622
The map basically looks like they just added +4 psi boost target to the MHD OTS map. Generally follows the same curve including the taper after 6500 for a "soft limiter". Maybe added 0.5-1 degree of timing target as well. WGDC is in the upper 90s so turbo is basically maxed as well (especially at 5200 rpm, its literally maxed). The boost drop off up top seems a bit more than you would expect. IIRC, BM3 stage 2+ logs show people holding nearly 20psi more consistently throughout the pull, not falling 5-6 psi below target in the upper RPM. For example in my log i just took yesterday i have basically the same or slightly higher actual boost in the upper RPM despite this target being higher. https://datazap.me/u/thejeremyman9/3...=0&data=4-5-17 It is what it is i guess. I wouldn't run the tune, its way too aggressive for stock turbo and HPFP IMO. |
10-04-2021, 04:54 PM | #20 | |
Rep 96
The custom tune power curve follows the OTS power curve on that graph. X5 has a different inlet designed than the f2/3x. That could be why it peaks a little lower in the rpm range than the f2/3x turbos. I haven't seen a stock turbo pwg car hit 17 psi on a single gear pull and I've tuned a few of them. Also, the dyno rpm scaling could be a smudge off. The dyno log revs out to 6.7k before shut down. Last edited by WOT808; 10-05-2021 at 07:13 AM.. |
10-04-2021, 10:58 PM | #21 |
Rep 2,376
Another tractor has been born...
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
11-17-2021, 09:31 AM | #22 |
Rep 96
Upgraded to an FX180 hpfp and run pump e85 now.
Haven't been back on the dyno but have been making some progress with my 0-60 and 1/8th mile times. Not bad for ~5k lbs with me in it. |
