trans service 06 e90 which kit to buy?
10-04-2021, 10:02 PM | #1 |
Rep 564
1. option 1 $330
https://www.fcpeuro.com/products/bmw...24152333907kt3 2. option 2 $180 https://www.fcpeuro.com/products/bmw...24152333907kt1 \oil change place said they saw transmission fluid leak. 06 with 98k miles. would you chose option 1 or 2?
F83 M4 - SIX SPEED
Build thread: 2015 F83 Mineral Grey 6-Speed Manual https://f80.bimmerpost.com/forums/sh....php?t=1856042 |
10-04-2021, 10:34 PM | #2 |
e91Owner
425
Rep 1,130
I wouldn't do either option, personally, but if you intend on keeping the car forever, using ZF fluid and returning it to FCP on your next fluid change might be economical. Otherwise, I would buy the hard parts from FCP and use MERCON SP which is the same fluid used in Ford ZF transmissions at a fraction of the cost. It's red unlike Lifeguard fluid.
As far as getting the mechatronic sleeves, if it's leaking from there, replace, if not leave alone unless you just want to do it as a preventative measure. |
10-05-2021, 12:47 AM | #3 |
Rep 445
First, are you SURE you have the ZF trans? GM has a metal oil pan, only ZF has the plastic pan.
I used the cheaper kit, along with a few extra bottles of the TopTec 1800, and bought all the Mechatronic seals separately. All the parts fit, and worked, just fine. Swapping out the Mechatronic seals is cheap insurance, once you have the pan off already. It can save you some major grief down the road if any of the old ones fail. |
10-05-2021, 12:50 AM | #4 |
Rep 564
Yes confirmed I have a zf
F83 M4 - SIX SPEED
10-05-2021, 01:10 AM | #5 | |
Rep 564
did you really use more than the 7 bottles? how many bottles should i buy? wonder they they only include 7 if more is needed?
F83 M4 - SIX SPEED
10-05-2021, 01:22 AM | #6 |
Rep 564
actually ordered the cheaper kit, with all the sleeves and 2 additional bottels. thank you! glad i asked
F83 M4 - SIX SPEED
10-05-2021, 06:46 PM | #7 |
Rep 1,682
I think the 7th liter is for insurance, depending on how level the car is, the temperature of the transmission and how long you let it drip, etc.
+1 get the cheaper kit and add on the sleeves as you did. I would change the differential oil too. |
10-06-2021, 12:15 AM | #8 |
Rep 445
Yes, I used a bit more than 8 bottles. After draining the oil, I left the drain plug out, started the engine, and let it idle for a few seconds, to get most of the remaining oil into the pan. Without that step, you'll only get about 6 quarts out.
10-06-2021, 12:17 AM | #9 |
Rep 564
Thanks I got 9 bottles in case!
F83 M4 - SIX SPEED
