      10-12-2021, 05:28 PM   #1
chef423
Drives: E90
How to remove the OEM hose clamps (E90)
How and the heck????
How to remove those suckers without damaging the OEM hose, that is the dilemma. Any folks with high EXP on those much welcome to comment.
Thanks,
Chef
      10-12-2021, 05:30 PM   #2
chef423
Drives: E90
Talking these (red lines)
Thanks
      10-12-2021, 08:32 PM   #3
Pittz1
2018 M3 ZCP / 06 330xi
212
Drives: 330xi 2006 / 18 M3 ZCP
I used a Dremel very carefully, then a pair of needle nose to pry it off. I also clamped further down the hose with pliers.
      10-12-2021, 08:34 PM   #4
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Curious why do you wanna remove the hose clamp but reuse the old hoses?
      10-13-2021, 06:59 PM   #5
chef423
Drives: E90
Good point. Ill check into the a new hose. My solution was to simply cut away the 1" or so of clamped hose as there was enough left to connect it correctly.
      10-13-2021, 07:04 PM   #6
chef423
Drives: E90
New hose comes with the plastic end I do not want, and said clamp thats a pain in the heck to remove, although completely off the car gives me a better advantage.
I upgraded that part to the Aluminum version for reliability. (pic shown but mine is aluminum in color as well)
      10-13-2021, 07:05 PM   #7
chef423
Drives: E90
Thanks. I ordered a Dremel 3000 yesterday with the small cutting wheels.
      10-13-2021, 07:18 PM   #8
tdott
Buy the correct part and you wont have that problem.
POBEP415.00
      10-14-2021, 02:13 PM   #9
Pittz1
212
Changed my Mickey Mouse flange out and have had zero problems. Just make sure you clamp off the hose about 6" down so nothing goes down in there. Absolutely no need for a new hose. 200k miles and still rolling.
      10-14-2021, 04:08 PM   #10
chef423
Drives: E90
Smart man on the clamp off, I notice that immediately that there could be an issue with dirt or worse dropping in that hose.
Thanks for the vote, the OG hose looks fine and was probably replaced at some point, looks newer...so I am going to stick with it.
Also, I use the 'Mickey Mouse' saying too, hilarious!
      10-16-2021, 09:32 PM   #11
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
I posted a DIY on exactly how to remove the plastic flange and band in the DIY section about 2 years ago.
