10-12-2021, 06:01 PM | #1 |
Rep 138
Radiator fan not working
Hi guys, so I recently had the pleasure of replacing my valve cover gasket and oil filter housing gasket. Well after all that, I was running my engine and got a overheating message and noticed that my radiator fan wasn't spinning. I tested it with direct power and it still didn't spin.
Now I did run a water hose down the front of my engine to clean off some of the oil, including down the radiator fan area. Could I be missing something here or did I fry the fan control module? I took it all out and can't really see a place where water would get into it but it's the only thing I can think of. Please help before I have to source a used one or something |
10-26-2021, 05:57 PM | #2 |
Rep 28
It happened immediately after replacing the VCG? After hosing the front too? Possibly might have fried the sensor or a sensor. If it happened immediately after, likely has to do with one or the other.
How many miles do you have? I had the same problem with my radiator fan not turning on and the overheating message. But it happened to me out of no where. Replaced my fan, thermostat, and water pump.. none solved it. It was the dme. Have it checked it out. If it’s not the dme then I can sell you my functioning used radiator fan. Hope this helps you. Would of helped me. |
10-26-2021, 06:06 PM | #3 | |
Rep 138
https://f30.bimmerpost.com/forums/sh...php?p=28164046 |
