10-16-2021, 05:18 AM | #1 |
Rep 1,386
ABS, trans/drive train power steering all failing at once
So I’ve been having my ABS flash up as failed recently and it vanishes within seconds, usually the radio goes quiet and sometimes the kombi goes dark but it sorts itself out within half a second.
This has happened maybe 3 or 4 times in the last 2-3 months, however after doing an airport drop off this morning it flashed up again, this time telling me of a drivetrain and transmission fault, along with no power steering and no internal electrics. It kept failing persistently over and over again, after the 5th or 6th time it stopped for around 60s before cutting the entire car power. The gearbox started whining as I came to a stop although I believe this may have been my ghost immobiliser locking the gearbox. I’m now kind of afraid to drive the car as it’s super random as to when it does it, but I lost power steering on a sharp bend and wouldn’t like to experience it again. There’s zero faults logged, nothing on the dash so it would seem to me like an electrical fault. Could I be right in thinking a weak battery might pose this issue? I did have a battery discharge warning yesterday as I had been working on the car with the ignition on. The only thing in common to trigger the issue is I have always been coasting
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
10-16-2021, 06:20 AM | #2 | |
1297
Rep 3,536
5w20283.50 |
10-18-2021, 08:57 AM | #3 | |
Rep 1,386
Haven't had an issue since, however I cannot read any codes until my new cable arrives tomorrow. Slightly concerned though as my O2 sensors have now died, I run a catless dp and doing 10k miles each year means every 12-14 months I have to buy new sensors due to them burning out.. so it's either a really weird coincidence or something isn't happy.
2015 435i - 401whp
10-18-2021, 09:55 AM | #4 |
Rep 1,386
Looks like it was an under voltage issue, looks like the battery condition majorly affected it. I'm going to look for a new and bigger battery, hopefully that'll help with any drain issues.
2015 435i - 401whp
n55david1297.00 |
10-18-2021, 12:59 PM | #5 |
Rep 7,622
Make sure you do proper coding/register for new battery once you get one.
fortythirtyfive644.00 |
10-20-2021, 10:10 AM | #6 |
Rep 1,386
Is there a health check I can do other than metering my battery?
I have used two different meters now on the battery and whilst running I was getting readings of 12-13v's.. when I check the codes via the MHD app however it's reporting mid 14's so I'm now skeptical whether the battery needs replacing lol
2015 435i - 401whp
10-20-2021, 11:52 AM | #7 | |
Rep 7,622
10-20-2021, 12:01 PM | #8 | |
@_sunbish
284
Rep 611
I would definitely replace the battery. |
10-20-2021, 01:01 PM | #9 | |
Rep 1,386
Yeah I'm going to just pull the trigger, need to do a bit of shopping tonight I think!
2015 435i - 401whp
10-20-2021, 01:16 PM | #10 | |
Rep 7,622
The car typically wont charge to 100% FYI. As noted above though its about more than voltage/%. It needs to be able to handle a load. |
10-21-2021, 05:40 AM | #11 | |
Rep 1,386
I managed to find a huge discount for a Exide 105ah replacement, it came down to £120 so I snapped it up
2015 435i - 401whp
