F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Some help about JB4(code 213601)
Studio RSR
      10-16-2021, 07:30 PM   #1
diddlkiss
Drives: 2010 335i E90 Lci N54
2015 F33 435i  [0.00]
2015 F82 M4  [0.00]
2011 F10 535i  [0.00]
2010 BMW E90 LCI 335i  [7.50]
Hey guys
I think JB4 keeps connected, which leads to too high sleep current of the vehicle. I got a quiescent current of 80mA-200mA at the dealership, but when I locked the car for about 1 minute, the Bluetooth was disconnected. Today I tried to remove the black ground wire of JB4, but nothing seemed to happen. It works well, Bluetooth works well, and OBD works well. I want to know the purpose of the black ground wire?
jb4 is V1 board with BT
and When I update the last firmware(JB4_P12_F_PWG_16_T3), I always feel the engine jitter when the accelerator is full. After loosening the accelerator, it returns to normal without any fault code. The sound comes from the right front of the vehicle. I think it may be the position of the turbocharger. In the update instructions, I noticed that the new firmware has modified the FUA, 50 is the most radical, but I saw that my FUA is 0. After several attempts, I go back to the previous firmware(N55_F_PWG_INT_15_T3). My car is 2014 F33 435I PWG (I'm sure it has a PWG), all stock,95ron gas. Another question is that I have been using map5. I don't think the improvement of map1 is obvious. Is this correct?
      10-17-2021, 04:48 PM   #2
435gc
435gc's Avatar
174
Drives: 2015 435i Gran Coupe xdrive
Ground wires are for exactly that, grounding.
Without logs its impossible to determine if map 5 or 1 is equal or better because map 5 is an auto tuning map. It will learn higher or lower based on a number of engine factors, primarily timing.
The other questions are better asked on the n54tech.com N55 support forum.
      10-18-2021, 03:45 AM   #3
diddlkiss
2015 F82 M4  [0.00]
When I removed the ground wire, nothing seemed to change, JB4 is working fine. N54tech nobody reply
      10-18-2021, 06:51 AM   #4
435gc
435gc's Avatar
174
Why would you remove the ground wire?
Did you start a thread in the support forum or general forum?
If your problem is the 213601 code, that signifies battery drain. If the jb4 is installed correctly it should be powered from an accessory fuse port that powers off after 15mins when the car is shut down.
Could be your battery is in its last legs or another aftermarket accessory is pulling power, like a dashcam, after shut off or jb4 is incorrectly installed.
      10-22-2021, 06:48 AM   #5
diddlkiss
2015 F82 M4  [0.00]
JB4 has an additional red wire and a ground wire. I installed it step by step according to the PDF. I connected the red power cord to the positive terminal of the cabin. It has a T45 screw, and I connected the negative pole to the grounding pile. Should I connect the red power cord to the fuse? Thank you for your reply.
      10-22-2021, 05:50 PM   #6
435gc
435gc's Avatar
174
Yes the red wire needs to get its power from a empty fuse slot. Preferably on that is an accessory slot that will only be powered when you press the ignition button. Its the black box on the left side of your photo.
Re attach the ground wire to a chassis ground point.
Where did you get this jb4? There should be an inline fuse along the red wire in-between the fuse box and the jb4.
      10-23-2021, 08:51 AM   #7
diddlkiss
2015 F82 M4  [0.00]
I have two JB4s, of which the circuit board of JB4_N55_REV2.0 was purchased on the burgertuning website in 2015 or 2016. In my impression, it should be used on my F30 328I, because the vehicle is for sale, it has been in the box. Another circuit board with stage2 was bought on the second-hand market in China. They don't have fuses, and they can work normally except for the code that generates 213601. Thank you very much for your help. I haven't received any reply to the same question at n54tech. Because my English is not very good, I haven't figured out how to set JB4. About 10 years ago, I used procede and meth for my e90 n54. It's really crazy. But when I switch to JB4, I always don't feel it at that time. I also used JB4+MHD backend for my n54 in 2018, but the improvement was not very obvious. It seems that there is not much choice for my F33 435i now except JB4. My 435 all stock only needs an increase of about 50 horsepower.
f30post
