10-31-2021, 03:14 PM | #1 |
Rep 1,682
PPF on Door Handles
I had my car fully PPF'd and the detail shop has done such an amazing job. You cant tell the car is wrapped at all, no seams whatsoever. When I brought it home I was inspecting the work and it took me a while to realize the door handles did not have any PPF on them. Took it back to the shop and they said XPEL does not have a template for door handles, however they can create a custom wrap but seams will be visible due to the curvature.
For those who have applied PPF to their door handles can you please post some close up pics so I can show the shop how it's done? I'm confident they are capable of wrapping it just want some ideas of what would be the best method. |
10-31-2021, 03:57 PM | #2 |
Rep 1,680
I'd be mainly concerned about the concave area of the door behind the handle; that's where careless fingernails tend to scratch the paint (especially passengers). I'd be fine with the handle itself left uncovered. If something were to chip or scratch it, it'd be a fairly easy respray or replacement.
10-31-2021, 04:05 PM | #3 | |
Rep 1,682
10-31-2021, 05:28 PM | #4 |
Rep 7,153
Drives: 2022 DG/BLk xDrive M4C Wk 34
Im dropping mine off on the 9th, and Im getting a complete custom install done. The detailer doesnt use templates, the whole car is custom cut and covered. They will be removing the door handles, and PPF'ng the whole outer skin of the door, in once piece, then wrapping it around the back of the door. The way the door handles are explained to me, is, hes only wrapping the front of the handle, there is a line in the handle that separates the front of the handle, from the back touchpad, only the front of the handle is getting wrapped, on my setup.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
10-31-2021, 05:41 PM | #5 |
Rep 2,744
I'm curious: Why not use templates? Isn't a custom cut a lot more labor-intensive (and potentially error-prone)? These cars are built to very tight tolerances...I can't imagine a template (if properly measured/cut) isn't good enough.
10-31-2021, 06:44 PM | #6 |
Rep 586
Depending on the installer, they will custom cut film to better hide any seams that may normally show. Some ppf installs only cover the panel and don’t extend around the panel leaving a clear line. Custom installs will wrap around the panel to completely hide the seam so you can’t tell it was wrapped even if you looked closely for it.
IG: Adaptiive_M
E46 M3 (Sold) E92 M3 2022 G82 M4C Xdrive |
10-31-2021, 07:21 PM | #7 | |
Rep 1,682
What brand film are they using? The way they explained it to me was the entire front of the door handle will be wrapped, the red lines in the image below is where the seam would be. I'm okay with that, but wanted to see if there was a way to avoid that. My other alternative was these carbon fiber door handles... https://autotecknic.com/products/aut...rim-set-g80-m3 |
Limegrntaln14100.50 BMWRacer5232562.00 |
10-31-2021, 07:27 PM | #8 | |
Rep 7,153
STek DynoShield
YT: G Dubyou Last edited by Limegrntaln; 10-31-2021 at 07:46 PM.. |
M_Adaptive1777.50 |
10-31-2021, 09:11 PM | #10 |
Rep 7,153
I believe you can add the extra in the program, not sure its automatic. All I know is, these guys do some of the best work in the area, and theyre pretty much famous for the cars they do around here.
YT: G Dubyou |
10-31-2021, 09:33 PM | #11 | |
Rep 1,682
10-31-2021, 10:19 PM | #12 |
Rep 914
Drives: 2022 G80 Comp x-drive
Not saying anything about a particular installer...but many "long time" or "old school" guys use no template as a badge of honor and almost an excise to charge more (look how good I am, i don't need no stinking computer). This is as true for window tint as it is PPF.
That said, some guys are so good it doesn't matter. Also, the large scale template cutters are very expensive, so maybe it's not worth it for them. |
10-31-2021, 11:46 PM | #13 |
Rep 788
My car is fully wrapped including the door handles, message me and I can give you my installers info and you can contact him and find out how he did the handles im sure he has up close photos of it too.
11-01-2021, 10:29 AM | #15 |
Rep 788
Here's the photos of the door handles, you can't even tell it's there I think.
iviegatron2623.00 |
11-01-2021, 10:47 AM | #16 |
Rep 1,682
11-01-2021, 11:04 AM | #17 |
Rep 788
I'm assuming it's on the inside too since that's a area that gets a lot of scratches from hands.
iviegatron2623.00 |
11-02-2021, 08:44 PM | #19 | |
Rep 1,801
11-02-2021, 08:52 PM | #20 | |
Rep 329
I dropped off my car off this morning at Auto Armour. https://autoarmour.com/. When i get the car back I will take a few pictures of the door handles. |
04-06-2022, 04:16 PM | #21 |
Rep 375
Anyone figure out how to remove the door handle yet. I need to take my car back to rewrap the door since my installer wrapped around the door handle and I do not like the look.
04-06-2022, 04:25 PM | #22 |
Rep 1,682
