11-01-2021, 08:08 AM | #1 |
Rep 13
Both Rear 12v Sockets not Working
Hoping someone can help point me in the right direction.
Recently picked up a 2017 X1 and noticed the front 2x 12V sockets are working but the 2 x rear are not. I checked Fuse #65 20A which looked fine but not sure if this supplies all 4x 12v sockets (doubtful @20A) or only the 2x front and maybe the rears have a separate fuse to check? Sheet in fuse box lists 63,65,100,115,132 but only 65 seemed accessible from the glovebox and others were either not fitted or not visible. Anyone had this issue before and found the solution? |
11-03-2021, 04:19 AM | #3 | |
Rep 241
kewe18744.00 |
11-03-2021, 03:18 PM | #5 |
Rep 7,584
Have the rear 12v sockets ever worked while the vehicle was in your possession?
I only ask because there are two different 12v socket sizes...and many BMW owners have thought that the sockets didn't work and the only problem was the incorrect size of the plug they were inserting into the socket. If you didn’t know…there are two sizes: 12-volt cigar lighter receptacle and plug, size A:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-05-2021 at 09:01 AM.. |
kewe18744.00 |
11-05-2021, 09:05 AM | #7 |
Rep 7,584
Here's a BMW SIB (service bulletin) PDF that describes how to address 12v sockets that don't work due to size incompatibility:
BMW SIB 61 01 20
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
kewe18744.00 |
11-10-2021, 07:07 AM | #8 | |
Rep 13
06-17-2022, 12:24 AM | #9 | |
Rep 17
hey I am having the same issue, by any mean, did you find out if the fuse 132 is the one? If yes, how could you access it? thanks! |
