11-01-2021, 03:34 PM | #1 |
Rep 28
Drives: 2015 BMW 435i
Location: Northern Virginia / South Jersey / Philadelphia
Bootmod3 Multimap n55
Can you run the OTS Stage 1 multimap without a flex-fuel setup or on regular 91/93 octane?
Can you create your own switchable maps? For example, if I wanted my stock tune for valet or family, stage 1 91, stage 1 93, etc? If so how would I do so? |
11-01-2021, 03:52 PM | #3 |
Rep 28
If I did want that kind of functionality I could get a custom tune to do so then?
11-03-2021, 04:13 PM | #5 |
Rep 263
You can create your own custom ROM map with up to 4 slots. Each can have different timing and boost, but if you want to mix and match existing OTS maps of your choosing, then no, not possible.
I created my own, using the M2 stage 0 as my starting point. Then made a modified boost map and a stock map. Still a work in process though. |
m4thijss6.00 |
11-03-2021, 04:15 PM | #6 | |
Rep 28
11-03-2021, 04:39 PM | #7 | ||
1297
Rep 3,536
he's custom making his own map
11-03-2021, 04:40 PM | #8 | |||
Rep 28
11-03-2021, 04:44 PM | #9 |
Rep 263
You can do that if you were ok with using the M2 tune instead of a stage 1 tune. It would still require you to copy tables from one map to the others, so not necessarily creating custom tunes - but does require some basic knowledge of using the map editor.
m4thijss6.00 |
11-07-2021, 12:31 PM | #10 | ||
Rep 5,399
m4thijss6.00 |
