11-11-2021, 01:16 PM | #1 |
Rep 3
Zappi charger advice required
Hi,
My new premier ix3 lands tomorrow after a short wait. I'm after some advice from anyone using a zappi home charger if at all possible please? 1/ Do you set the charge time on the car or the charger? 2/ what settings do you use for a over nite scheduled charge 3/ any other advice? Many thanks 👍👍 |
11-11-2021, 01:28 PM | #3 |
Rep 78
Zappi 2 here. Car doesn't arrive until Monday but I have spent way too much time lookong into this!
Set car to charge immediately and leave it like that all the time (you need this at public charge points anyway). Have Zappi on eco but set boost for your preferred charge hours/time. If you then just plug in and lock the car, the charge will kick in as soon as the Zappi fires up for the boost. Job done! |
11-11-2021, 02:05 PM | #4 |
Rep 601
Yeah, it's the way I'd do it too, it's annoying getting to a public charger like tesco and whatnot, going shopping to come back and realise you haven't told it to charge as the timer was on.
11-12-2021, 07:04 AM | #5 | |
Rep 126
From experience: Leave the car on immediate charging. Control timed charging from Myenergi App. I made the mistake to use the timed charging om the car, but when you connect for public charging you need to change settings. When you forget to change there is no charge at all!!! |
11-16-2021, 12:24 PM | #7 |
Rep 164
Bear in mind that as Winter begins, you will need to think about battery preconditioning. My experience with the i3 is that this is best done by leaving the Zappi on Fast and then setting charging times in the car along with a departure time.
Doing it on the Zappi requires two boost periods which is a bit of a faff IMO. |
11-17-2021, 02:24 AM | #8 | |
Rep 132
11-17-2021, 06:04 AM | #9 |
Rep 78
Did a timed charge using the boost timer on our zappi for the first time last night (car set to charge immediately)....car was parked, plugged in and locked about 7 hours before charge kicked in. All worked fine.
I hadn't thought about battery preconditioning before departure, so I guess ours has been doing it using the 'main' vehicle battery. Hmmm |
11-17-2021, 10:28 AM | #10 | |
Rep 164
After 6 years of driving just EVs , I have got myself into the mindset of thinking that all EVs would have battery conditioning (heating and cooling). Last edited by DaveCV; 11-17-2021 at 10:44 AM.. |
11-18-2021, 03:52 AM | #11 | |
Rep 132
DaveCV37.00 |
11-18-2021, 12:21 PM | #12 | |
Rep 247
11-19-2021, 02:54 AM | #13 | |
Rep 164
IX3 Vines19.00 |
11-19-2021, 10:27 AM | #14 | |
Rep 247
