11-12-2021, 03:24 PM | #1 |
Rep 3
1st week of ownership then drive from Cornwall to Windermere... And then back
Evening,
My IX3 is due next week and on Friday I have to drive from Newquay (Cornwall) upto the Lake District. Then Return again a few days later I'm genuinely concerned about range & charging anxiety so early into my 1st EV ownership. Luckily at the hotel they have 2 charge points so can charge up once at Windermere. Can anyone recommend any chargers on the M5 North & South preferably near Tewkesbury and North of Manchester as I think I'm going to need to x2 charges. I keep looking at zap maps but can only find 7kw at places like a council hall when I ideally want a minimum of 50kw at a service station. Any recommendations would be appreciated or do I leave it at home and hire a car instead. Many thanks 👍👍 |
11-12-2021, 04:20 PM | #3 |
Rep 42
I found that "a better route planner" was better than the zap map for route planning. You can filter the chargers on the route to ccs at 50+ to save you seeing all the 7 etc.
From my experience of semi long trips, albeit not in an ix3 - shell, instavolt and IONITY chargers are very reliable. BP on the other hand are very temperamental when I've tried to use them. |
11-13-2021, 03:25 AM | #4 | |
Rep 8
Charge Points - Podpoit
Just checked on the Podpoint app. Lidl at Droitwich have 3 50kw chargers. In Kendal there are 2 22kw chargers at Ullswater garage. There are more but you need to look closer. If you download the Podpoint app you can pre-load a sum of money to make the whole thing quicker. Looks do-able. |
11-13-2021, 04:56 AM | #5 |
Rep 164
It amazes me that anyone is concerned about range in a 280 mile EV. I recall my first i3 had a maximum range in summer of 80 miles and, with some careful planning and a bucket load of patience, long trips were not an issue. My advice, FWiW, is always have a Plan B to cater for blocked/in use/unserviceable chargers.
PS. The chargers in Kendal are tricky to find and traffic can be a nightmare. A number of Booths Supermarkets have Instavolt chargers. |
11-13-2021, 05:24 AM | #6 | |
Rep 840
When the car arrives, register it to your BMW account through the My Drive app. Then download the BMW Charge app - login with the same username and password - it will ask you to sign up to a charging plan, and will offer you the 1 year free IONITY/BP package. They will post out a smart card to use the chargers - but many of them can apparently be activated through the app. Cullompton Services on the M5 has a number of IONITY 350kw chargers. These should give you a quick boost, and at a discounted price through the app. It is also on a junction, and hence accessible from both directions. So should give you a squirt on the run downhill back to Newquay. |
11-13-2021, 06:32 AM | #7 |
Rep 601
Yeah registered mine last night and cancelled the plan (pay) I had with the PHEV, oddly though can't re register the card I already had, they have to send me a new one? Mad bit of a waist of plastic, but whatever
11-16-2021, 01:41 AM | #8 |
Rep 51
Abetterrouteplanner is indeed a great tool.
The day after delivery of my iX3 I started a week's holiday driving from The Netherlands to Denmark (and back of course a week later). With abetterrouteplanner it was a very easy experience. Its predictions are very close, but always a little on the pessimistic side which is great. The range prediction by the car itself is also quite pessimistic, allowing more range than it tells you in advance. I very much prefer that to having it the other way around... My tip to you is to download that app (or use the website) and plan with it. And as said before: make sure you have a plan B in case of defective/blocked chargers. Have a great trip! |
IX3 Vines19.00 |
11-16-2021, 02:29 AM | #9 | |
Rep 132
11-16-2021, 05:17 AM | #10 |
Rep 601
ABRP also works great in Android Auto, and can be set as the default mapping app if you like.
11-17-2021, 11:29 AM | #11 |
Rep 840
I drove from Plymouth to Bedford last night.
My registration on the BMW Charging app had been successful. Smart card dispatched, but not yet received. The range would have allowed me to reach the IONITY charger at Chippenham. However, I stopped at the IONITY at Cullompton Services to check it out. At Cullompton, only one of the chargers was occupied, at about 5pm. The app allowed me to unlock the charger and it all went smoothly, with a 20 min boost. At Chippenham, 2 of the 4 chargers were occupied. Another 20 min boost there. Brief pause to check out the IONITY charger at Milton Keynes coach station - one of the bays occupied by a Taycan. We stopped for a bite to eat at Peartree Services on the A34 near Oxford. A problem with the Ecotricity charger. The plug was loose and worn. When I unlocked the car it drooped in the socket and cancelled the charging session. Locked the car before starting the session and it worked well. Very pleased with my first long trip. |
11-18-2021, 03:47 AM | #12 | |
Rep 132
