11-18-2021, 10:43 AM | #1 |
M340i
396
Rep 988
Drives: BMW M340i
BM3 tune through Ipad?
I thought there was an option to tune BM3 from an ipad with an enet cable. Not wirelessly. Is this no longer available? I downloaded bm3 to my ipad and have a lightning adapter to the enet cable but when plugged in it does not see the dme. I've sent an email to protuning freaks but have not heard back yet.
11-18-2021, 10:49 AM | #2 | |
1297
Rep 3,536
11-18-2021, 11:04 AM | #3 |
Rep 890
On latest iOS, you have to enable Local Network access for tuning apps to be able to see the DME (under Privacy settings). Maybe that’s the issue?
11-18-2021, 12:49 PM | #4 |
Rep 3,703
Same issue with my iPhone 13 Pro.
PTF told me it has to do with mfi certification changes in the latest iOS and some lightning to ENET adapters are not working now. They recommended this one to me, which is arriving tomorrow and I’ll try it this weekend: Ethernet Adapter Compatible for iPad,iPhone 11,X,XS,XR,8,7,6 Lighting to RJ45 Ethernet, USB Camera. LAN Wired Network, Data Sync with Charge Port https://www.amazon.com/dp/B087WHHDWR...S6A6A0QBZDK3FH BTW, my iPad Pro M1 works just fine with the latest iOS via the USB C port using a hub with ENET, so def seems to be a lightning ENET mfi issue. |
visionaut1317.50 |
11-18-2021, 03:27 PM | #5 | |
Rep 1,066
It's the older devices thus far for a direct connection on ios14 or android it seems. Have local access checked off as well.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
11-18-2021, 04:14 PM | #6 | |
Rep 3,703
Will try the PTF recommended adapter this weekend. |
11-18-2021, 04:30 PM | #7 |
Rep 1,066
I have tried it with 2 different bmw obd2 to Ethernet cords. If you have one and it works for you, please post it. I'd prefer not to have to carry the laptop around all the time to log.
I've tried the following cords : New 2M Ethernet to OBD Interface Cable E-SYS ICOM Coding F-series for BMW ENET https://www.amazon.com/dp/B00MECEI14...JA1G7JY315X2SX Arteckin ENET Interface Cable (OBD2 to Ethernet rj45) for BMW Coding Diagnostics https://www.amazon.com/dp/B07MTGDSDS...YCBCM2WEB8XZND
11-18-2021, 05:25 PM | #8 | |
Rep 3,703
Are you saying separately that the OBD/ENET adapters you posted are not working with your laptop? |
11-18-2021, 05:54 PM | #9 |
Rep 1,066
With the adapter you linked:
I can flash maps but not log via ios15 + iPhone 13. With the two cords I posted above + Ethernet to usb c adapter, I can flash and log with laptop. Thus if you have a different BMW ODB2 to Ethernet cord than one I posted above and your linked adapter works with flashing + logs, post it so I can do the same
ZM22827.50 |
11-18-2021, 05:56 PM | #10 | |
Rep 3,703
11-18-2021, 06:07 PM | #11 |
Rep 176
I can flash and log on my ipad mini and iphone 12 running ios 15.1 with this adapter. https://www.amazon.com/dp/B093T8HBDR...tning+to+ether I can even listen to BT music the same time.I know that doesnt always work. So my Ipad stays in the car full time and handles my BT Music, Gauges and logging.The thing with these adapters is they can stop working any time apple releases an update. I use to have an MFI certified one from anker that ended up breaking, but they stopped making them.
EDIT. I found the Anker one that is guaranteed to work. It pricier, but I dont mind paying because I know it wont stop working one day. https://www.amazon.com/dp/B08PFG6R9R...f_=as_li_ss_tl
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
11-18-2021, 06:21 PM | #12 | |
Rep 3,703
Hopefully the one PTF recommended works for my use case, but I知 not optimistic at this point! |
11-18-2021, 06:46 PM | #13 | |
Rep 1,066
11-18-2021, 08:21 PM | #14 |
Rep 176
im using this one https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Bought it April 2020 and havent had any issues .
11-18-2021, 10:21 PM | #15 | |
Rep 932
ZM22827.50 |
11-20-2021, 04:55 PM | #16 |
Rep 3,703
So, the adapter I linked to seems to be working great. Here's a quick 4th gear pull I did earlier today with it and my iPhone: https://www.bootmod3.net/log?id=6199...729b67b25b0e88
I also did a couple of logs just driving around town that were 3min & 5min each, both looked good. I looked at my OBD/ENET adapter and it is completely unbranded. I got it 4-years ago from Okee at codemycar.com, back before bimmercode or BM3 OBD flashing were even a thing. I've used several different Cat 5/6 cables with it and it has always worked fine via laptop, and now is back to working fine with the new Lightning/ENET adapter. PS. I also ripped a 7.1 & 7.2s 100-200kph right after this! Last edited by ZM2; 11-21-2021 at 12:37 AM.. |
