12-13-2021, 12:59 AM | #1 |
Rep 220
VTT Crank Seal Guard
Hey All,
I just installed the VTT Crank Seal Guard. interested to see if anyone else has used this? I found it is not a very good fit and flexes out near the top. this then causes a noise when the car is on. Wondering if anyone else has had the same issue? And does anyone have any recommendations on which one would be best to get? The Kies motorsport one does look pretty good. I will be using it with the VTT crank bolt capture. |
12-14-2021, 05:03 AM | #2 |
Rep 220
Worked it out. Install error by me, needed to push it flush to the engine better, must have backed out a bit when I did it last time
All sorted now |
imperfectluck428.00 |
12-16-2021, 12:13 AM | #3 |
Rep 292
Drives: 2014 335i 6MT MSport
Good to know, mine has been sitting on my kitchen table for about six months...
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
12-16-2021, 03:11 AM | #4 | |
Rep 220
I did it from the top, there is no need to go via the bottom. I highly recommend removing the radiator fan. Was so simple, 2 screws, one power plug and one locking tab. Took 5 mins the first time I did it. Rest was super simple, I do recommend a friend when you are putting the crank back on, as trying to keep placed properly is an art. I reckon I can do it in under 20 mins now... |
12-16-2021, 06:26 AM | #5 | |
Rep 5,399
One really smart Kies feature is it has an actual bolt shape on its outer surface so you can still hand turn the crank at any time without having to remove everything and deinstall it from the engine. When steel bolts are used with an aluminum part, a washer is required to spread the force out so that the steel bolt head doesn't dig into the softer aluminum. Keeping tiny washers on each bolt is a pain to deal with while working in an awkward position trying to find the hole, hand tighten and torque each bolt. Instead Kies has engineered a superior solution. Rather than 6 or 8 tiny washers Kies uses a large central washer to apply consistent pressure across the face of the Bolt Lock that's attached to the crankshaft. It is so much easier to install while in an awkward position and it does a much better job. Kies didn't cheap out. They use the correct materials for a moist outdoor engine environment. Stainless steel and zinc coated steel are expensive, but they are engineered to provide proper corrosion protection. The other product on the market uses black oxide bolts and washers. Black oxide is a cheap coating that's used to make steel parts black. But it's not meant to provide any corrosion protection. Black oxide is specifically meant for dry environments, not an outdoor moist open air engine environment! Remember high school science class. Iron oxide is rust. Black oxide is basically black rust. I'd never use black oxide bolts and washers on my expensive BMW engine. Another great unique product from Kies! Comes in blue and a stealthy black. And for 6-bolt and 8-bolt cranks. Check it out! https://www.kiesmotorsports.com/prod...9554517?aff=22 |
