12-13-2021, 03:44 PM | #1 |
Rep 62
M240i Wheel Fitment
Just a little back story, I work with an aftermarket wheel company and they are in the process of developing/releasing a new wheel for the G42 platform. The team picked up a sick Brooklyn Gray spec and we went to work right away. For reference the brand is Curva Concepts and with this new young team, they are looking to completely restructure the brand.
Anyways, to the good stuff. I don't want to spoil the fun yet with offsets and whatnot, but I think if you're looking for 18"/19" track set ups, you can go pretty beefy. You can also run a 20" comfortably for those looking to go larger with the wheels. Based on some different options, we think we can squeeze a 10" wheel in the rear with sufficient clearance for beefy tires. |
SN1P3231.00 vampire81508.50 MPSdriver192.00 MisteClueless35.50 XC3LLR82086.50 MarkFine16.00 Brett_C_F30_G42386.00 VegasG42693.00 |
12-18-2021, 05:01 PM | #3 |
Rep 139
Subbing in on this thread...am interested to see what options you come up with....
2016 Ram 1500 Sport Crew White 2014 BMW 435i XDrive M-Sport Sapphire Black 2008 BMW 135i Alpine White (sold) |
12-20-2021, 04:02 PM | #4 | |
Rep 25
12-20-2021, 04:53 PM | #5 |
Rep 94
Im hoping to run 19x9 in the front and 19x10 in the rear. TE37s. Please please please keep us posted on all of your findings!
01-06-2022, 04:02 PM | #9 |
Rep 60
01-19-2022, 03:11 PM | #10 |
Rep 62
02-09-2022, 12:34 PM | #11 |
Rep 1,559
02-23-2022, 05:54 AM | #12 | |
Rep 610
I am confirming my 19x9 and 19x10s too.
Currently Driving: '23 G87 M2, '22 BMW M240i xDrive, '18 F87 M2, '98 E36 318is @AUTOID | WWW.AUTOID.CO | SALES@AUTOID.CO |
02-23-2022, 06:10 AM | #13 | |
Rep 1,461
Drives: BMW X5M Comp
These guys claim they are genuine wheels and have the BMW G42 M240i X-Drive series specs on their site and they make sense But I spent a few hours at our local wheel manufacturer who is huge here in Australia (Koya Wheels) and I'm looking at some forged wheels Tyre sizes 245/35/19 and 285/30/19. This keeps the diameter within the required 1% of the X-Drive spec and works out to .4% (same as the stock 225/40s and 255/35s I'll get all the figures soon but one of the factors was brake clearances not so much on the width of the callipers but they are very tall and come close to the barrels. The fully forged wheel is a good way around this to give adequate diameter on the inner barrel These will be a very tight fitment and when done I'll post the specs and pics All the other usual stuff getting done this week |
02-23-2022, 06:51 AM | #15 | |
Rep 1,461
https://tiresize.com/comparison/ The 265/295 comparison is a tad out (1.1%) difference in diameter for X- Drive requirements but 295/30. /255/35 is the identical diameter and perfect for X drive require specs but the fitment of 295s on the back was too ambitious according to the guys who did all the measurements. 285/30 and 245/35 is the best all around match with a tight fitment on a 10" and 8.5" wheel. I'm guessing this won't look to shabby |
02-23-2022, 09:50 AM | #16 |
Rep 100
Probably a better choice, but smaller than factory. I would hate to give away miles to smaller tires. My speedometer already reads about 3mph faster than GPS.
02-23-2022, 12:22 PM | #17 | |
Rep 1,559
If you meant the latter, then the diameter difference is 4%, not .4%. Regarding the OEM 225/35 and 255/35, the diameter difference is 3.2%. Does this 1% variance mean any change needs to not exceed 3.2% by 1 percentage point, so anywhere between 2.2% to 4.2% between front and rear is acceptable? If the above is true, then a 245/35 front and a 285/35 rear is about as large of a delta as you can go w/o exceeding 1 percentage point of 3.2%. Someone please check my math and correct me if I'm not getting this. |
02-23-2022, 03:13 PM | #18 | |
Rep 84
XC3LLR82086.50 |
02-23-2022, 04:01 PM | #19 | |
Rep 1,461
Agreed OE options are 225/40 front 255/35 rear or optional 245/35/19 wheels front 255/35/19 rear. I used an online calculator to get the max tyre diameters that could be used with X Drive limitations and had less that a 1% rolling diameter difference between front and rear wheels Largest usable combination that would fit the car were 285/30/19 rear and 245/35/19 front Attached is a screenshot of the calculator result showing .4% difference between front wheels and rear wheels, also for reference the same calculator results for the OE 255/35 rear 225/40 front |
02-23-2022, 04:34 PM | #20 |
Rep 1,559
My bad, didn't realize the 225 was a 40 ratio. I ordered the ZTK package which has a 245/35 and 255/35. The delta there is 1.1%, so I guess that's BMW approved.
02-23-2022, 04:55 PM | #21 | |
Rep 1,559
Looks like the website I was using has a 1mm difference in diameter compared to the website you're using, but should be close enough that the transmission won't know the difference. According to Tire Rack, and in regards to the ZTK package, an 8.5" wheel can handle a 255, while a 9.5" wheel can handle a 285. This means a 255/40 front and a 285/35 rear will give you a -0.4% difference, which should be a nice meaty look if that's your thing (which it is for me). *Ignore the wheel width's and offset's in the screen shots below. I was only interested in tire width and diameter. |
02-23-2022, 06:19 PM | #22 | |
Rep 1,559
Size 1 and Size 2 below can serve two purposes: 1) It can show the difference between the OEM size and the new wider size on the rear of the ZTK (graphically and data), or 2) It can show the differences with a new front/back setup on the ZTK (graphically). Last edited by XC3LLR8; 02-23-2022 at 06:29 PM.. |
