12-17-2021, 09:11 PM | #1 |
Chief Petty Officer
Rep 517
ZF8 version in G42?
Anyone know what version of the zf8 is in the G42? Was reading something today that the G80/82 xdrive are running the zf76. Trying to figure out what the limit of the tyranny is.
12-18-2021, 06:32 AM | #3 |
Rep 875
8HP51 (Gen 3) Gear Ratios:
1st gear 5.25 2nd gear 3.36 3rd gear 2.17 4th gear 1.72 5th gear 1.32 6th gear 1.00 7th gear 0.82 8th gear 0.64 Reverse 3.71 Fluid Capacity: Roughly 6 liters Fluid Type: ZF LifeguardFluid 8 or equivalent Torque Limit: 500 NM (369 lb-ft) https://blog.fcpeuro.com/zf-8-speed-...cs-maintenance ZF 8-Speed Transmission Upgrades The 8HP45/50 may only be rated to just under 400 lb-ft of torque, but ZF’s other 8-speeds, like the 8HP70, can hold significantly more. Swapping from an 8HP45 to 8HP70 is possible and has been done before in BMW’s 3-series. It requires a new flywheel, recoded TCU, the 8HP70, and some other supporting bits but gives you an OE-spec transmission capable of holding twice the advertised power of the 8HP45. Any more torque than that, though, and you might want to consider other options. The easiest way to beef up your 8HP45/50 is with an upgrade package, like those offered by Pure Drivetrain Solutions. They offer four different packages; the weakest rated at 750 lb-ft and the strongest capable of over 1200 lb-ft of torque. Each transmission is fully disassembled and features stronger clutches, stronger seals, and a few modified internal pieces. The strongest gearboxes also receive shafts, hubs, and baskets made from billet aluminum. The N55 or B58 engines mated to the 8HP are capable of some serious power; these transmission upgrades will ensure their reliability and longevity. |
Hendo741645.00 |
12-18-2021, 08:44 AM | #5 | |
Rep 875
At ECS there is the page showing the application for it due to this pan being offered as a replacement https://www.ecstuning.com/b-ppe-part...228053400~ppe/ |
12-18-2021, 08:55 AM | #6 |
Rep 875
A nice more in-depth technical and engineering review of the ZF-8
https://www.thetruthaboutcars.com/20...eed-automatic/ |
12-18-2021, 11:46 AM | #7 |
Chief Petty Officer
Rep 517
This was my thought. I believe the Supra comes with the ZF8HP51 and it holds 500-600 wtq before it requires upgrading. Hence the question and see who had what data.
12-19-2021, 10:41 AM | #9 | |
Rep 875
510NM and he feels will easily take 600+ with the built in overcapacity We chat today after he did the research. 51=510Nm per the catalogue. BMW Z4 (G29) Jaguar XE 20d RWD , Toyota Supra (A90), 2019-up |
VegasG42373.50 |
12-19-2021, 11:29 AM | #10 |
Chief Petty Officer
Rep 517
12-19-2021, 11:47 AM | #11 | |
Rep 875
Accounting for more is not something they design for in the factory. The higher power applications built in the factory gain the more capable ZF8 that is available for the designer to utilize. Bottom line if you want the better or more capable gearbox you buy the more powerful model lol. This is rather normal overall. That being stated there are aftermarket solutions to gain power in the gearbox. For the average non -tracking driver they will be pleased with this package of motor and ZF8. Overall the ZF8 configurations are durable. I am not worried at all with the stock configuration. |
12-19-2021, 01:20 PM | #12 | |
Chief Petty Officer
Rep 517
Who keeps cars stock?? 🤣🤣 The major appeal of the G42 is the B58TU and its capabilities with minor modifications. |
12-19-2021, 04:52 PM | #13 |
Rep 111
It's probably similar to the Supra. Fine with bolt ons and tune. Once you go bigger turbos and E85, it will depend on how you drive it.
Most modified/tuner cars make quite a bit more than manufacturer rating before it becomes a problem. Last edited by kumizi206; 12-19-2021 at 05:01 PM.. |
12-19-2021, 10:07 PM | #14 | |
Rep 274
That being I think BMW should give the transmission reasonable headroom for mods (without increasing costs too much). |
02-12-2024, 11:29 AM | #15 |
Rep 31
Oh I'm not quite sure about this when certain cars are chosen, like the M240i or the Supra. I think a lot less than 95% keep these babies stock
