12-21-2021, 07:30 PM | #1 |
Rep 119
Best spark plug for E30 Applications
Hi,
Which is the best spark plug for E30 applications? I heard NGK 97506, as well as BMW 12120042724 FLEX FUEL SPARK PLUGS. Which gap to use? I'm currently on a Bootmod3 stage2+ e30 tune. Might go Pure Stage 2 in the future. Won't be going full E85, just keeping E30 for fuel economy. Thanks in advance. https://bootmod3.atlassian.net/wiki/...+and+which+gap |
12-21-2021, 07:37 PM | #2 | |
1297
Rep 3,536
12-21-2021, 10:33 PM | #4 |
Rep 119
But I am running more boost and timing? Bootmod3 recommends NGK 97506:
https://bootmod3.atlassian.net/wiki/...+and+which+gap I am also tuning a friends car, N55 PWG, with a Pure Stage 2 Turbo. They are running the NGK 97506 as well, just wondering if there is a better option. |
12-22-2021, 04:02 AM | #5 | |
1297
Rep 3,536
and no, there is no better options.
johnung4537.00 |
12-22-2021, 05:57 AM | #6 |
Rep 187
Drives: BMW F36 435i FBO
Stock is the way to go.
Bosch ZR5TPP330 at stock gap. You want the biggest gap possible without spark blowout for a more complete combustion. Better combustion better power |
12-22-2021, 12:00 PM | #7 | |
Rep 7,622
My 45k mile OEM plugs did fine at E30 before i changed them and replaced with new OEM... also people run OEM plugs with PS2, meth, etc all the time. Correct |
lucasborka41.00 |
12-24-2021, 10:41 PM | #9 |
Rep 2,376
Stock plugs at stock gap = winner... See my mods in the description
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
12-26-2021, 06:07 PM | #10 |
Rep 119
My tuner had me put in NGK 97506 @ 0.18", I'll stick with his recommendation and tune the car like that. Then I'll switch maybe to the stock plug and stock gap, see if I don't get timing pull/lose power. Sounds like a good plan?
12-26-2021, 07:48 PM | #11 | ||
Rep 5,399
I contacted them and pointed out that by default a Stage1 tune is supposed to mean that the hardware is all stock. (Except of course for the poorly designed F30 N55 chargepipe) As far as I know they ignored my suggestion to clarify that stock plugs & gap should used for BM3 Stage1. Guys are so used to looking for and assuming that every part has an upgrade. There is no such thing as a spark plug upgrade! BMW engineers chose the stock plug and gap because it provides optimal performance for the engine. With spark plugs- if it ain't broke don't fix it. If it's running fine, then there's no upside to changing plugs/gap. It can't get better. It can only get worse! "Spark blowout" was mentioned as a reason for different plugs/gap. Spark blowout is actually a misnomer. The spark doesn't blow out. It never gets started. It can happen with very high boost tunes because they jam a much higher than usual number of fuel and air molecules into the engine cylinder. It creates a traffic jam of sorts. One solution would be electronics with a stronger spark like a race team might do, but it's easier to switch to a colder plug with a shorter gap. But there's often a trade off. For example an engine may not idle as smoothly. For a newly tuned N55, I would suggest installing a set of new stock Bosch plugs at stock gap out of the box. There are about $9 each. Then see how it runs. Learn how to collect logs. If there are issues never suspect plugs first. Always make sure that fuel quality is high enough. If local 93 gasoline quality is suspect then add 1-2 gallons of E85 to the tank. Or flash down from the 93 tune to the 91 Octane tune. If those things improve engine smoothness and performance then it's fuel quality not a spark plug issue. There are plenty of posts about how to visually inspect plugs to determine how an engine is running. Hope this helps someone! |
lucasborka41.00 |
12-27-2021, 12:14 PM | #12 |
Rep 7,622
That gap is extremely small for the vast majority of people. Unless you have some extreme setup/fueling/etc its probably totally unnecessary. If your tuner requested it then go for it so the car behaves as they are expecting but that doesn't mean its the ideal setup.
Pussiwillow522.00 |
12-27-2021, 02:04 PM | #13 | |||
Rep 187
johnung4537.00 |
04-13-2024, 03:24 AM | #14 | |
Rep 13
Drives: BMW F30 328i
04-13-2024, 03:28 AM | #15 |
Rep 13
FYI as to how much HP I am running it's about 150 over stock.
04-13-2024, 11:30 AM | #16 |
@_sunbish
284
Rep 611
NGK 97506 with out of the box gap, .031”.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
