BMW X5
      12-23-2021, 11:55 AM   #1
Trex1200r
Drives: 2022 X5 M50i, Audi SQ5
Exhaust Tips M50i
Thought I would post this here as it is strictly a cosmetic mod.
Found these on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I like these because they have a factory look to them.
I was able to get these pushed on so the tip of the exhaust pipes tucked nicely into the edge of the sleeves, but it took some moderate cutting on the two inside tips (the tips closes to the hitch). I cut 1/4" off of the back end of 2 sleeves so it would clear a bend in the pipe.
Others have installed them as well and are saying they were able to just push them on, but not sure they are getting the edges tucked into the rim or not.
Anyway, price is right and I like the results. They have been on for a few months now with no issues.
Here is a thread with some other options. Thanks to ninefourteener for doing the research on the dimensions needed.
https://g05.bimmerpost.com/forums/sh....php?t=1732018
Appreciate 17
Russ103308.00
Bearco65.00
Burnt C6257.50
3Wagon129.00
Tch-Nrd124.50
sssmokie125.00
Blue87375.50
1Boxer34.50
Inglewood432.00
BSfmAZ94.50
sabrina493.50
1230vani652.50
      12-23-2021, 12:06 PM   #2
TGTBTU
TGTBTU
TGTBTU's Avatar
Drives: 2022 X5 X-drive M40i
Looks like a very clean install and it looks great.
      12-24-2021, 12:45 PM   #3
Russ103
Drives: 2021 X5 M50i
Looks great! And for $20 I see no reason to not try it
      12-25-2021, 08:36 PM   #4
NYCX5M50i
Drives: 2021 X5 M50i executive/DHP
Looks Clean
      02-06-2022, 07:08 AM   #5
NCRob
Drives: 2021 BMW M5C
I too added these to my X5M50i. Well worth $10 ea and about 1 minute total installation time!
      02-06-2022, 10:50 PM   #6
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
Check the orientation on mine. It's a little different than what you did
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
mmm50i405.00
      02-07-2022, 06:47 AM   #7
NCRob
Ah, yes that does look better with those pronounced ends on the inside. I’ll have to adjust mine! Anyway good thing about this mod is a really quick fix to reposition
      02-07-2022, 11:42 AM   #8
JimVR4
JimVR4's Avatar
Exactly! I have the angles from left to right instead of top and bottom. They line up beautifully 😍
iStep 03/2023.50
      02-07-2022, 09:30 PM   #9
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
Did you cut yours as well?
No. Try not. Do. Or do not. There is no try.
-Yoda
      02-07-2022, 11:05 PM   #10
JimVR4
JimVR4's Avatar
No cutting needed
iStep 03/2023.50
      02-08-2022, 06:40 AM   #11
NCRob
No cutting needed on mine either
      02-08-2022, 10:49 AM   #12
Trex1200r
Just to reiterate my post. Cutting is only required if you want the sleeves to push on all of the way. If you don't mind the exhaust within an exhaust look there is a ton of adjustability to orient the depth and angle and installation is as easy as it gets. Either way, you have options, all of which are an improvement over the thin little factory pipes sitting there.
      02-26-2022, 02:52 PM   #13
BMWoody
Drives: X5
Just got mine in the mail today. Will have to try a couple different angles
      02-27-2022, 02:03 PM   #14
BMWoody
Drives: X5
Anyone have any issues with them falling off?
      02-27-2022, 04:56 PM   #15
NCRob
None here and I have the same vehicle. Mine are so tight they require a lot of effort to pull off and reposition.
      02-27-2022, 11:21 PM   #16
JimVR4
JimVR4's Avatar
I've had them on for a while. They never move
iStep 03/2023.50
      03-03-2022, 06:14 PM   #17
mmm50i
mmm50i's Avatar
405
Drives: '22 X5 M50i & '23 Model Y
Wow this looks great. It looks like you positioned them so that the extended portion of the tip (elongated tip) is facing the center of the car? Is that what you were referring to?
I'm going to order these tonight
      03-03-2022, 07:31 PM   #18
JimVR4
JimVR4's Avatar
Yes that's right. It's such a simple and solid install. Props to the OP for finding these!
iStep 03/2023.50
      03-10-2022, 10:32 PM   #19
skindoc
Drives: 2022 BMW X6 M50i
Anyone have a tip on how to get them off after install? They are on pretty tight. Wanted to changed the angle a bit and didn't wanna yank too hard and screw something up
      03-11-2022, 06:21 AM   #20
NCRob
You won’t do any damage pulling them off by hand. You do need to get a good grip so thin grip gloves might help you. Although I’m able to get mine off OK with nerve damage in my fingers so you should be fine.
      03-15-2022, 09:21 PM   #21
elite-fusion
Drives: 335xi
Will these fit a 19 x5 xDrive50i?
Not sire if its the same as the M50i but assume it is, ut figured I would double check to confirm
      03-15-2022, 09:24 PM   #22
elite-fusion
Drives: 335xi
CN you please elaborate what difference you have vs others. Sorry just not seeing the difference unless i am overlooking it lol
xbimmers
