      12-24-2021, 02:44 PM   #1
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
Drives: 22 M4CX / 18 TTRS
G42 2022 M240i Dragy fun: 0-60 and 1/8 mile (vs RS3 and Supra times)
BIMMERPOST
     Featured on BIMMERPOST.com
Merry Xmas Eve fellow lurkers! Or happy whatever day you want it to be if Xmas isn't your flavor. I come bearing gifts of Dragy times for my G42! Hit 1k miles and decided that'll do. I didn't do a slow break in, I've definitely mashed it before today, but this is the first timed runs as well as using the launch control for me.
I am going to post some other dragy sheets for comparison purposes. let me say this, I am genuinely impressed! She's a chonky girl, but she will get up and move!! It is actually faster than it feels. I did the runs, then looked down and was like "WTF!"
Comparison cars are 18 RS3 (with the better transmission and LC than 19+) both stock and Unitronic stg 1+ 93 ECU stg 2 TCU, and a 21 Supra 3.0 with JB4 map 2 with 295/35 falken RT 660 tires. All of these runs are unprepped surfaces no burnouts, but driving warm tires.
With out further ado, cheers:
Appreciate 16
      12-24-2021, 09:49 PM   #2
vampire81
vampire81's Avatar
553
Drives: '19 ZL1
It's a quick car
      12-25-2021, 12:15 PM   #3
Ricochet48
Drives: 2006 RSX-S (IL), 2024 X3 (FL)
It's honestly fairly incredible how quick cars are today.
The old Supra, RX7, 3000GT, and even NSX I idolized in high school were 5.0-5.2 second 0-60's. At <3.9 the M240i is in the same league as an older Viper, 911 GT3, R8, or even Modena 360.
I honestly do not see the need for more straight-line speed, especially as the vast majority of my driving would be in the city anyways.
Anyways, more specifically I'm impressed how much it beats the Supra off the line (AWD FTW). Understandably the lighter Supra seems to be catching up right after though.
      12-25-2021, 02:55 PM   #4
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
The AWD is why I bought this car. Definitely impressed with the grip and launch control from a dig. The Supra here isn't stock either. JB4 map 2, which is +4 lbs of boost. The M240 is certainly impressive in stock form and has a hell of an upside with the B58TU under the hood and AWD.
yanks1487.00
      12-27-2021, 01:27 PM   #5
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
Are you planning on running a JB4 unit on the M240? Wondering if one can get away with a JB4 stage 1 (with 91 octane) on the newer B58 engine as i assume boost has already been upped to get the increased HP. I am currently running a jb4 unit on my GTI and like it. Just wondering if folks have played with the JB unit on this revamped B58 engine and if stage 1 would be pushing it beyond what 91 octane would allow. (91 is all we can get here, yes i could add e85 but that is uncommon as well.)
thanks for posting
      12-27-2021, 02:41 PM   #6
SupraCooper
SupraCooper's Avatar
Drives: 94 6spd turbo Supra
thanks for posting
thanks for posting
You should be able to run any map with it. I emailed Burger and the jb4 does in fact work with the new g42 m240i. I got mine in the mail the other day, and still waiting on my car on order 🤣
      12-27-2021, 02:44 PM   #7
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
I can neither confirm nor deny that the JB4 is in the garage waiting for break in oil change and inspection to be completed this later this week before install.
I will say this about the JB4. They are very octane dependent. Even on 93 they will tend to pull timing when upping the boost without some sort of octane booster or E85 blend. Definitely wouldn't go above map 1 (+3 psi) without adding some juice.
      12-27-2021, 02:52 PM   #8
danallxt
danallxt's Avatar
Like Hendo says, it is very octane dependent, NO way with octane 91 you can run ANY map with the JB4. I'm frankly wondering if even the stage 1 map can be run with octane 91 without pulling timing, especially in hot weather.
      12-28-2021, 12:55 PM   #9
AlpineBoost
AlpineBoost's Avatar
3894
Drives: '23 Civic Type R
Nice results. Zupra seems a little slow, no? I thought independent testing showed 2021's stock are sub 4s.
      12-28-2021, 02:14 PM   #10
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
I'm sure it's capable of sub 4 in the right scenario, but in my experience it's just extremely traction limited. With perfect conditions and a perfect launch, or prepped surface, sure. Real world daily stuff, good luck.
Traction is the main reason I ditched it for the M240. The interior and tech is just a bonus lol
      12-28-2021, 02:35 PM   #11
AlpineBoost
3894
Gothca, guess I was just thinking with tune/tires that it would be there even on the street, but if traction is that bad then it makes sense.
      12-28-2021, 04:40 PM   #12
stylinexpat
stylinexpat's Avatar
438
Drives:
I have not yet seen the 1/4 mile trap speed numbers yet for the M240i. Would love to see those. If with a small tune it could hit 120 MPH would be nice
YS115.50
      12-28-2021, 04:57 PM   #13
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
I posted them in another thread. 12.1 @ 113. Not too shabby for an almost 4000 lb car.
      12-28-2021, 05:16 PM   #14
sikotic
Drives: 2020 M340I
Wow I thought the M240I weighed less than the M340i? It looks like its about 30lbs heavier unless I looked at the wrong data..Im shocked. I guess thats awd vs rwd but I thought the M240I would weight much less being a coupe
      12-28-2021, 06:28 PM   #15
Lightngsvt
Lightngsvt's Avatar
620
Drives: 2022 G20 M340i
The M240 xDrive is only 50 lighter than the M340 RWD. But it's about 150lbs lighter than the M340 xDrive.
Chuck
2022 G20 M340i PB/Oyster
Last- 2018 F30 340i 6MT ZHP AW/CRed
      12-28-2021, 06:29 PM   #16
stylinexpat
438
Drives:
The Supra is around 117 MPH so 113 is not so good. Needs to be able to trap higher speeds I reckon for the way it accelerates off the line and with the amount of power and and Torque it has
      12-28-2021, 06:43 PM   #17
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
The car is just fat and needs a diet 🤣
The extra 500 lbs definitely shows itself up top.
      12-28-2021, 11:43 PM   #18
Ziosella
Ziosella's Avatar
70
Drives: EX Bmw 430i now M4F82
Modern tyres and electronics make a huge difference, despite 3/400 kg more to drag.
      12-29-2021, 11:44 AM   #19
AllaVodka
Drives: BMW B58
Still think the new s3/rs3 will outcompete this new 2 series. Small 4 door sedan, that seemingly feels and looks more like a classic 3 series than bmw's current 3 series. Interior looks great as well. Just my .02.
      12-29-2021, 12:59 PM   #20
zipstic
Drives: 2008 e92 335xi
2008 335xi Coupe  [10.00]
The RS3? Yes.
The S3? Not so much.
Of course it depends on what you mean by outcompetes.
https://g42.bimmerpost.com/forums/sh....php?t=1882028
sikotic610.50
      12-29-2021, 06:57 PM   #21
Hendo741
Chief Petty Officer
Hendo741's Avatar
690
Originally Posted by zipstic View Post
The RS3? Yes.
I was going to link this video lol. M240 wrecked the S3! And coming from someone who owns an RS3, the M240 has very similar performance for less money and fairly equal interiors imo. I personally prefer the M240 interior, but to each their own. The M2 should be the direct competitor to the RS3, but the M240 does a hell of a job dollar for dollar. If it were just a few hundred lbs lighter it would win hands down.
TJZ67201931.00
      12-30-2021, 04:16 PM   #22
YS1
Drives: G87
Based on the dragy numbers and having owned a Uni stage 1 RS3 as well, I would agree that in a straight line they should be neck and neck stock for stock.
