White 335i sedan Single Turbo plus spares
12-25-2021, 02:51 PM | #1 |
Rep 4
So this is my hobby car. Fully built this to be a sleeper and daily driver. However I have a new Tesla inbound so I’m taking offers on my complete car plus huge full supply of spares etc. I know I’m forgetting some items here just because there is so much to list here. I’m fully expecting lots of questions. Please ask questions and I can send pics. White/beige 2007 e90 AT 335i sedan sunroof with nav and idrive shows 169””” miles. No accidents and clean title. Completely stock and original inside and outside. There is some wear and tear including small dents scratches etc. Full budget has been spent under the hood. Blank slate exterior. (Have not started on the rest of the car yet). I bought this car at 162,000 with a bad motor knowing I was going to build it out. Now after the build it has 169,000 and is fully broken in and ready to run. I’m only running 14psi pressure for daily use. Suspension and wheels tires have been upgraded. Fully built motor includes: Machined block with upgraded sleeves. Ceramic coated JE forged pistons Molnar H beam rods Ceramic coated king bearings 8 bolt crankshaft Pinned crank hub New front and rear main seals All new seals and sensors through the entire engine. Garett ocd6251 liquid cooled dual ceramic ball bearing turbo Ceramic coated turbo housing Speedtech bottom mount kit Fully CNC ported cylinder head New valves and fully serviced head Super tech valve springs RCB pcv delete head New cam bearing trays New Teflon cam seals Nexus B58 coils and plugs. New HPFP New water pump New thermostat New powers steering pump New ax compressor New radiator New AC compressor Stepped CHF intercooler Doc race charge pipe Turbo smart wastegate Tial BOV Dual oil catch cans W450 bucketless LPFP Holley Hydramat All new fluids/filters/gaskets everywhere. Software tuning by jake@motiv Rebuilt AT XHP stage 3 Sport steering wheel with paddles New M3 control arm kit New bilstein B8 kit. 18 inch matte black 030 wheels New Michelin tires Plus all my spares…so this is where it gets big. Takes up a whole bay in the garage M3 LSD M3 rear axles M3 drive shaft MT drive shaft New set Sparta slotted drilled brake rotors Spare complete N54 (disassembled) Spare A/T Spare x MT Additional (3rd) cylinder head VTT single and Double barrel kit new (never installed) VTT modified fuel rail 12 additional fuel injectors 12 ignition Coils Oem 17 wheels 2 oem HPFP LPFP Water pump Full wiring harness 2 vanos solenoids Fully machined crankshaft Several sets of king bearings Huge lot of seals and gaskets All the original spare parts and ducting etc. from the original vehicle which were still functioning including turbos are still here and included. |
12-26-2021, 11:25 PM | #2 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
What are you asking?
Who built the motor and head? |
