| 01-27-2022, 07:20 PM | #1 |
Rep 310
Tire and increased speed limiter
Hi all,
Just saw that there's no increased speed limiter on my build. I got the performance runflat. Does that not come with the increased speed? Thanks!
I doubt, therefore I might be.
| 01-27-2022, 07:38 PM | #2 |
![]() ![]() 259
Rep 326
High Performance tire package comes with increased speed limiter as well as coding for increased cooling, as well as 245 width tires up front. I think it's the ZTK package at $2500 US.
Retired: '08 335xi E90. "Long may you run."
Retired: '19 M240xi "You also" |
| 01-27-2022, 07:45 PM | #4 |
Rep 196
You will be getting the option 840 (High speed limiter) added when you get the performance tires. The list on mybmw app sometimes takes a while to reflect the updates. Your CA should be able to confirm looking in his portal as well.
| 01-27-2022, 07:52 PM | #5 | |
Rep 310
| 01-27-2022, 07:54 PM | #6 |
![]() ![]() ![]() 378
Rep 438
I'd check with the dealer to confirm it's right. You can also look at the order guide (see stickied post) to confirm you picked a wheel/tire combo that includes it. Search for "will add 840 to the order".
| 01-27-2022, 08:00 PM | #7 | |
Rep 310
| 01-28-2022, 11:59 AM | #10 |
Rep 706
The "no additional cost" tire wheel options (US Order form) are impressive in the range of choices, far more than i have seen from other manufacturers.
Some things are a bit weird tho. There are 4 choices for performance tires (non-all season), 1PW, 1VX,1VY, and 1VZ. What is weird is that the only one of these (1VZ) that gives you the wider 245 series front tires does not show a 840 increased top speed limiter? All the other performance tire options do show the 840 increased speed limiter. I wonder if this is just an omission error in the order sheet? Perhaps like the 1VY option that has 19" wheels but specs a 18" tire for those wheels, that will be interesting to see how they get those 18" tires on the 19" wheels? ![]() |
| 01-28-2022, 12:05 PM | #11 | |
Rep 310
| 01-28-2022, 12:30 PM | #12 |
Rep 706
oops, correction to my above post. I overlooked one (the 1PP option) so there are 5 performance tire/wheel no cost options, 2 of them do not list the 840 increased speed limiter (1PP and 1VZ)
| 01-28-2022, 12:32 PM | #13 | |
Rep 196
It would be a bonus if I get 245's but I guess I just have to wait to see when my car eventually comes in. |
| 01-28-2022, 12:42 PM | #14 |
Rep 438
Looks like you needed to go for 1VX to get the increased limiter with the same wheels. You wouldn't get run flats that way, but some of us would consider that a huge improvement.
| 01-28-2022, 01:04 PM | #15 | |
Rep 310
| 01-28-2022, 01:25 PM | #16 |
![]() 62
Rep 84
I also optioned 1PP specifically to get the top speed limiter removed. Its the same tires and sizes. Why do we not get the option....
| 01-28-2022, 01:28 PM | #17 |
Rep 438
It's not the same tires, they're run flats. And it's not really about the size, it's about the speed rating, which I assume is different for the different tires.
| 01-28-2022, 01:54 PM | #18 | |
Rep 310
| 01-28-2022, 01:55 PM | #19 | |
Rep 310
| 01-28-2022, 01:59 PM | #20 |
Rep 438
Good 4 2 reasons965.50 |
| 01-28-2022, 03:03 PM | #21 | |
Rep 310
| 01-28-2022, 04:57 PM | #22 |
![]() 62
Rep 84
Me as well, my car is on a ship. This is disappointing. I'll talk to dealer about it.
| Bookmarks |
