01-29-2022, 05:19 PM | #1 |
Rep 171
Top speed limiter - user configurable!?
The 130mph top speed limit for cars with all-season-tires has been discussed here in length. I recall someone even asked their dealer for a top speed increase. It seems like there's no need for that ...
I bought a M240i for my wife which came with Bridgestone Turanza LS100A. This is NOT the tire for this car. I decided to replace them after 600 miles with Michelin Pilot Sport 4 AS (which are outstanding btw!). After a couple of miles, I got a warning that the tires weren't recognized and that I needed to "configure" the tires myself. I could select the type (summer, winter/all-season) of the tire as well the dimensions. The last selection was the speed rating. Unfortunately, with all-season you can only select 100mph or >100mph (which I think means 130), for the summer however it appears that the limit is 155mph. Anyone else tried that? |
01-29-2022, 05:23 PM | #2 |
Rep 425
That setting only changes the recommended tire pressure for the TPMS -- you're supposed to inflate to a higher PSI when driving >100 mph.
It has absolutely nothing to do with the speed limiter, which by now is locked into the DME and can't be changed. |
01-23-2024, 03:37 PM | #4 | |
Rep 542
I just see automatic and manual. Manual allows me to select the tyre type but not the +100mph setting. I have the summer tyres 255/35/R19 96Y with ZTK. |
01-23-2024, 03:58 PM | #5 | |
Rep 2,543
The optimum pressures for the load of vehicle is on the door sticker. You are not going to be driving at sustained speeds above 100mph but if you were, the advice used to be add 0.3bar. Don’t know if technology has negated that approach now though. |
01-23-2024, 03:59 PM | #6 | |
Rep 542
Also I will be doing some period of 100+ |
01-23-2024, 04:04 PM | #7 | |
Rep 2,543
You can select between winter and summer tyres. You won’t be doing sustained 100mph plus. You’ll run out of petrol after 5 miles |
Evilmoretea275.00 |
01-23-2024, 04:10 PM | #8 | |
Rep 542
https://g87.bimmerpost.com/forums/sh....php?t=2075128 |
01-23-2024, 04:50 PM | #9 | |
Rep 2,543
The change in the idrive for tyres is to adjust the recommended pressures for your tyre type. You have the Ztk pack so assuming you buy the recommended winter tyres, the recommended pressures are the same as the summer ones. If you want to increase pressures for high speed driving, do so but don’t rely on the TPMS. |
01-23-2024, 04:53 PM | #10 | |
Rep 542
