what's wrong with my BMW?
02-09-2022, 07:11 PM | #1 |
Rep 2
My 2006 BMW 325xi is having a misfire problem.
it's throwing multiple misfire code on all cylinders and it makes the car shake and jerk really bad, this started next day after fixing an antifreeze leak I had for a few weeks. The weird thing is the misfire goes away after turning the car off and on a few times, sometimes it takes quite a few a tries. However, this is only a temporary fix and the misfire soon returns. I replaced all spark plugs and problem continued, I was thinking of replacing coils as well but then I decided to try and disconnect the valvetronic motor and proceeded to run the car and it ran smoothly (hesitates a little to start up though). So now I'm thinking it's the ESS or possibly the valvetronic motor. Any thoughts on what it could be before I go out and buy anything? |
02-09-2022, 09:37 PM | #3 |
Art Collector
2427
Rep 3,450
Yeah definitely don't guess. As mentioned above, you NEED a code reader. Whether that's a cable and software or something handheld, it'll pay for itself the first time you use it.
02-09-2022, 10:14 PM | #4 |
Rep 462
Go get a proper BMW scanner. You cant own these cars without one. Otherwise take it to reputable bmw mechanic and have them diagnose it then fix it yourself. Don't tell them you just want a diagnostic obviously.
02-10-2022, 01:28 PM | #6 |
Rep 4
02-10-2022, 01:32 PM | #7 | |
Rep 4
Current Fault Log ------------------ P0300: Random/Multiple Cylinder Misfire Detected P0301: Cylinder 1 Misfire Detected P0302: Cylinder 2 Misfire Detected P0303: Cylinder 3 Misfire Detected P0304: Cylinder 4 Misfire Detected P0305: Cylinder 5 Misfire Detected P0306: Cylinder 6 Misfire Detected P1017: Unknown code - More information may be available on the web Pending Fault Log ------------------ P0341: Camshaft Position Sensor "A" Circuit Range/Performance (Bank 1 or Single |
02-10-2022, 02:28 PM | #8 |
Rep 1,080
Eddy, I can't answer your big question, but when you turn of the engine and start it up again, the computer allows the cylinders to run until the computer again senses misfires and shuts the cylinders off again.
As you have learned, you can do this as many times as you want. |
02-10-2022, 03:40 PM | #9 |
Rep 29
Maybe your car jumped timing? I think that's pretty uncommon on these, but that cam position sensor code is an issue.
If I were you I'd take it to a shop and have them diagnose. Sounds pretty serious. |
02-11-2022, 07:20 AM | #11 |
Rep 1,579
Check the ground strap from the frame to the valve cover. The brown wires that bolt into the metal valve cover ground all the coils. Where was your coolant leak?
02-12-2022, 06:07 PM | #13 |
Rep 4
02-12-2022, 06:12 PM | #14 |
Rep 4
The hose that connects to the radiator wasn't properly inserted into the radiator and with enough pressure it would just pop out and leak the entire coolant
03-15-2022, 12:47 AM | #15 |
Rep 2
UPDATE: I was able to get back into my account.
Also it turns out it was just a dirty/faulty VANOS solenoid. I removed and tested both of them and exhaust side VANOS was completely stuck. I gave it a good clean, tested it again and it looked like it worked fine again. I installed everything back in and the car started too run smoothly. However, a few miles later it looks like it got stuck again and the car would stop running and not wanna stay running for too long after turning the key. Good thing I was parked outside of Autozone when this happened, I went into Autozone and bought a new VANOS solenoid, installed it on the spot and now my car is running like a champ without the recurring rough idle again. Moral of the story: when Youtube recommends you 1000 videos of mechanics telling you to check you're VANOS, maybe listen so you wont have to spend time and money fixing what you think is the problem Last edited by Eddynandez; 03-15-2022 at 12:59 AM.. |
