Seat Occupancy Bypass help!
02-10-2022, 04:02 PM | #1 |
Rep 21
So I got the notorious restraint system malfunction. I ordered one of those Ebay occupant and seat belt bypass modules. Installed easily but the light is still there. I used the proper switch combination and still no luck. Are these things supposed to work right away?
My mechanic could not clear the code also. Any tips? Thanks, |
02-10-2022, 04:35 PM | #2 |
Rep 1,232
I was able to code out the airbag warning on my 2007 which got rid of the error code and I left the seat occupancy sensor in place as is.
I used Carly for BMW to code it out BTW. |
StradaRedlands4998.50 |
02-10-2022, 05:46 PM | #3 |
Rep 13,122
You have to install those before you get the error .
If you do get them you need the BMW software to reset. Like BMW standard tools with Inpa or Ista D. |
02-10-2022, 08:42 PM | #4 |
Rep 4,324
Any bypass that will work for the car will work right away. The code can be cleared with any srs/bmw scan tool.
If it’s not clearing, the bypass isn’t working or you have other errors.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black E91 328 M Sport-Alpine over Black-Alpine over Saddle brown. E93 335i-DINAN tuned. Alpine over Saddle brown |
02-10-2022, 08:55 PM | #5 |
Rep 43
I agree with Serf. If the bypass is made correctly and you have it connected correctly, it should clear. I would like to add that I once chased that code around for quite a while because of a bad battery.
02-11-2022, 12:09 AM | #6 |
Rep 26
02-16-2022, 05:22 PM | #8 |
Rep 1,232
02-25-2022, 09:55 AM | #9 |
Rep 26
IG: 3DIRTY8
02-25-2022, 10:29 AM | #11 |
Rep 1,232
Ok so when you go into the "customization" menu you should see the car figure out what modules you can communicate to and from that list I selected "CSM" on my vehicle.
It will then make a backup of the existing configuration and in the next screen you will see an option called: "Seat belt reminder passenger". As you can see in the screenshot that is attached in my vehicle that has a failure with the seat occupancy sensor the option is set to "off" This prevents the passenger seat belt light from showing up on the dash like it used to since the occupancy sensor thinks that someone is sitting in that seat where there isn't. |
