UK E91 2007 Headlight Query
02-11-2022, 04:49 AM | #1 |
Rep 20
Hello,
Firstly, apologies if this is answered elsewhere, but i couldn't find the answer specifically for the UK Right hand drive variant. I have a 2007 E91 with angel eye head light option and I need to give the bulbs a once over. Some online help \ tutorials I've seens say i need to remove the wheel and inner wheel arch cover in order to check \ change the angel eye bulbs. Is this correct? Sounds a bit extreme, especially as there is an access point within the wheel arch? Thanks in advance. |
02-11-2022, 11:28 PM | #4 | |
Rep 400
Drives: 2011 e91 328i RWD
I’ve pulled all front and back arch liners to clean out the crud and it’s really not that bad. I pulled the front splash shield too. Good luck! I’ve been to Coventry btw when I worked for The Kinks years back. I have a TR6 too and I know Triumph was made there! |
02-11-2022, 11:59 PM | #5 | |
Rep 58
In my case I did not need to remove the wheel arch in order to change the bulb for the angel eyes. Just remove the cover in the picture, which should give you access. You need to feel where the bulb goes, but it is definitely doable without removing the wheel arch. The extra wire you see in my picture is because of LED conversion. |
02-12-2022, 08:46 AM | #6 | |
Rep 4,330
can you access the bulbs through the little access hole? Yes. Is it a lot easier and less frustrating to just pull the front half of the liner down? Also yes. |
02-12-2022, 08:52 AM | #7 | |
Rep 4,330
It's way easier to do it with the wheel liner removed. Here's the back of a prelci euro bi xenon, but my US ones look the same. |
Mike K332.00 |
02-16-2022, 12:02 PM | #8 |
Rep 20
Thank you all for your feedback!
Really don’t want to start removing the arch lining etc if I really don’t need to. Mostly because it’s using a hammer to break a walnut! Lol As it’s the passenger side, it looks like I can access it from above if I remove the main light cover as well. I might give that a go and see how I get on… Firstly though I need to find replacement bulb(s)….. |
02-16-2022, 06:46 PM | #9 |
Rep 4,324
The small access door does not give you access to the cover for the angel eye bulbs.
The angle eye bulbs are also held on by 2 long Torx screws. You can probably do it from the top, but it will be difficult to guide the socket into the torx screws. It will also be a lot more difficult to line up the new bulb and screws back in place. Removing the wheel/ wheel liner will be faster than trying to do it from the top.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black E91 328 M Sport-Alpine over Black-Alpine over Saddle brown. E93 335i-DINAN tuned. Alpine over Saddle brown |
Mike K332.00 |
03-07-2022, 10:02 AM | #10 |
Rep 20
Gave in and left to a mechanic i use...
He found that the light lense is faulty due to water inside the light :-( Looks like the last person to look at it broke the covers etc :-( Nevermind and who knew bulbs could be so difficult!.... Thanks all for your comments... |
03-07-2022, 01:21 PM | #11 |
Rep 222
on my 2007 e93 335i to change the angel eyes I can do it from top. To change the main headlight bulb need to remove inner wheel arch cover for easy access.
