What size/type battery is right for my 2011 e92 335is?
02-12-2022, 12:31 PM | #1 |
Rep 281
If read conflicting things online. Some say H6 or H8. Should it be an AGM? This is the current battery I have but my stereo install guy said it looks a bit small for what my car should have.
02-12-2022, 12:45 PM | #2 |
Rep 13,122
I agree it looks small they usually take up the entire space.
A 49/H8 would . Also missing is the foam on the end that is bumper for the H8 Size. Should say on the top of the battery what size it is. If you put in a larger battery you will have to program for type and amp hours. To find out what it is programmed for you will need some kind of BMW diagnostic setup. BMW standard tools and Ista D recommended. Bimmergeeks Pro Tool if you want phone diagnositcs. My last Interstate 49/H8 lasted 10 years and I could have gone farther. Do you know if that is the original battery if not you will need the diags. Depending on what you are putting in you may or may not need bigger but these car are noted battery hogs on there own. Stereo board on e90post says you can go up to 2000 watts of aftermarket stuff before there starts to be problems. Last edited by ctuna; 02-12-2022 at 01:08 PM.. |
02-12-2022, 01:06 PM | #3 |
Rep 281
02-12-2022, 01:13 PM | #4 |
Rep 13,122
There is the long metal screw with a kind of bracket .
Mine has a foam insert to .(see some of the ytube install video's) Mine has a hard foam end piece never heard of a problem never seen one without one but I don't look at this that often. There are many threads here on battery replacement and programming. Lots of ytube video's some show the foam piece. look it up on RealOem.com Last edited by ctuna; 02-12-2022 at 01:20 PM.. |
02-12-2022, 03:24 PM | #6 |
Rep 1,080
First, you live in CA, and you could probably get away with a motorcycle battery.
Are you having battery/electrical issues? Remember, when the car is running, the alternator is what powers the car. The battery just starts the car, and in extreme cases might supplement the alternator. Now if you're planning to run your new stereo for hours and hours while the car is off, you might need a much bigger battery or even a second battery. Be happy and forget what the installer said. |
02-12-2022, 04:20 PM | #7 | |
Rep 281
02-12-2022, 06:01 PM | #8 |
Rep 281
I'm having a new battery put in right now. I'm confused because people have been saying to use an H8/49 battery but it doesn't fit. So I have to go with the H6/48. I don't know why it works for some people but it's too big for my car which is a 2011 335is.
02-12-2022, 06:56 PM | #10 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
H6/H8 both fit, that triangle tie down bracket at the very bottom has 3 different mounting holes iirc, at least 2.
Get a lightweight AG H6 40ah Li battery
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
02-13-2022, 09:48 AM | #11 |
Rep 1,080
What is the alternator charging voltage with the car running?
Did this problem start with your new stereo? What is the battery voltage after it sits overnight? You need a cheap multimeter or: https://www.amazon.com/s?k=cig+light...ref=nb_sb_noss |
02-13-2022, 11:19 AM | #12 | |
Rep 281
02-13-2022, 12:49 PM | #13 |
Rep 13,122
Did you do an OEM idrive install .
If it's aftermarket I drive maybe it wasn't wired in correctly . Maybe the car is not going into sleep mode. What do you have that is constantly on? |
02-13-2022, 05:00 PM | #14 |
Rep 1,682
Maybe the dashcam was drawing power at all times, draining the battery.
In the picture you have one extra threaded hole for the battery bracket. Therefore if the old, short one was H6, then you should be able to fit an H7, which is about a 1.5" longer. From the picture, H7 may be the largest you can fit in there, if the current one is H6. I think the battery is mainly held by the bracket at the bottom. The foam might be a crash safety thing, because it pretty much drops right in, and that is not going to be holding anything as heavy as a battery. H7 (Group 94R), the length is about 12-7/16". H8 (Group 49) is 13-15/16". Unless the shop only has a H6 (Group 48), which measures 11". |
02-13-2022, 06:30 PM | #15 |
Rep 1,080
With as much feeling as I can muster, you probably don't need a battery. You have another problem that is causing your problem, like the recently installed equipment.
That said, how many times has your battery gone dead, and how many times has it been recharged. Also, how old is it? |
02-15-2022, 08:44 AM | #17 |
Rep 3,696
@Slim415 - where about are you located, I am near Laguna Seca Raceway? I have a coding cable and my laptop is setup with INPA.
Do you know how to access your Hidden Menu in the Kombi? that is going to be a great diagnostic tool to see how your battery voltage is holding up over nite. Which new battery did you install? * AGM/FLA? * 60/70/80/90/110 AH? * H6/H7/H8? What did you do with the old battery? (keep it or gave it back as a core charge already)? Did you update the VO? Did you recode the car? Did you register the new battery? Last edited by fazman; 02-15-2022 at 08:53 AM.. |
