All are N52 E90 headers the same?
02-14-2022, 12:32 AM | #1 |
Art Collector
2427
Rep 3,450
Just wondering if there’s and difference in fitment between 325, 328, 330, as well as xDrive vs. RWD variants.
From what I understand there isn’t, but just wanted to confirm. Thx!
02-14-2022, 02:34 AM | #2 |
Rep 4,324
They have different part numbers but they should be the same in terms of functionality.
Mounting wise, they are the same, including SULEV. There is a difference from rwd/xi and lhd/rhd.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black E91 328 M Sport-Alpine over Black-Alpine over Saddle brown. E93 335i-DINAN tuned. Alpine over Saddle brown |
02-14-2022, 08:46 AM | #4 | ||
Art Collector
2427
Rep 3,450
Okay thanks guys. I noticed aftermarket header options all seemed to have common fitment across E9x models (and E82/88 I believe). But then I noticed part numbers differed on RealOEM. That all makes sense.
02-14-2022, 10:14 AM | #5 |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
RealOEM shows me the same PN for 325i and 330i, but different for the 328i, so I wonder if it was changed for the N52k for some reason. I'm sure they will all bolt up but there must be some difference.
https://www.realoem.com/bmw/enUS/sho...diagId=18_0587 https://www.realoem.com/bmw/enUS/sho...diagId=18_0587 https://www.realoem.com/bmw/enUS/sho...diagId=18_0587 |
02-14-2022, 10:52 AM | #6 | |
Art Collector
2427
Rep 3,450
Sorry—I should have been clearer upfront: My concern is limited to the compatibility of aftermarket options. It sounds like while BMW might have different PNs and even slightly different designs, when it comes to aFE or AA for instance, they’ve got just one product for the whole N52 E9x range. I’ve ordered some headers, but panicked after I realized the product description didn’t explicitly mention the 328. Will post about them once they’re here.
02-14-2022, 11:03 AM | #7 | |
Neo-Luddite
2614
Rep 1,401
e90yyc2426.50 |
02-14-2022, 01:18 PM | #8 |
Rep 4,324
I meant the shape on rwd models are the same from 325-330.
The mounting points should also be the same between rwd and xi but xi has a different shape/length for the awd system.
02-14-2022, 03:55 PM | #9 | |
Art Collector
2427
Rep 3,450
So, when it comes to aftermarket headers, they’re shaped in order to permit installation on both RWD and xDrive cars. Am I getting this lol?
02-14-2022, 04:49 PM | #10 |
Rep 4,324
I looked at some eBay vendors.
They’re listing the same headers for both Rwd and awd. I guess they’re the same. I pulled some rwd and awd headers off a couple of minutes hrs ago. I should’ve snapped some pics! The rwd was a lot easier to get out than the awd. With either one, reinstalling is a task I would not want to do.
02-14-2022, 05:32 PM | #11 | |
Art Collector
2427
Rep 3,450
Indeed, the origin of my confusion was the seemingly universal application of the aftermarket products (AA, aFE, no-names), but the very limited application for each original PN. In my case, my sole concern was making sure the headers I ordered will fit, but then of course my curiosity kicked in. With AWD the subframe is such a bitch to work around. I don’t look forward to doing this job, but I do look forward to being done it. Thanks!
02-14-2022, 07:08 PM | #12 | |
Rep 4,324
Maybe the OEM part numbers change because different material is used for the catalytic converter… The rear nuts on the rear manifolds where nearly impossible to see. I was just feeling around for the nut and guiding the air ratchet to it. The xi subframe was the biggest issue. I think 1 manifold came out but the other one didn’t want to. It was getting stuck on this bar that goes across the subframe. I cut the bar and bent it out of the way to get the manifold out, haha. Good luck!
02-14-2022, 07:16 PM | #13 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Only difference I'm aware of is RHD vs LHD
02-14-2022, 08:27 PM | #14 |
Art Collector
2427
Rep 3,450
Ding ding ding. I think we have a winner.
Makes me wonder what the technical differences between the BMW PNs are, but between when I first posted this and now, I’ve come to this same conclusion. They all fit—even 1 series and some X5s even??—but the only physical limitation is RHD/LHD. Thanks everyone for helping me understand this.
02-15-2022, 12:00 AM | #15 | |
Art Collector
2427
Rep 3,450
Did you go at them from inside the engine bay with the coolant expansion tank removed? I’m hoping access isn’t too terrible but I suspect it will be…
02-15-2022, 01:28 AM | #16 | |
Rep 4,324
These were just 2 parts cars that were pretty much done. I did most of it from the top of engine bay. Some manifold bolts I had to get from the bottom of the car. The coolant tank was already removed. So that does make it easier. I remember an ac line bolted to the AC compressor either being in the way of a manifold nut or making it hard to access the nut, so I unbolted that line. Unbolting them from the rest of the exhaust on the bottom was easy. Removing the nuts from the front manifold(near radiator) wasn’t too bad. I don’t think it will be hard for you to put those nuts back on and torque them. Rear manifold, the forward nuts are still accessible. The rear nuts near the firewall were the ones I just felt around with my fingers to find. This is the point at which I said “I would hate to have to reinstall these nuts”. I used these tools. Different lengths for different nuts that required more or less space. 3/8” ratchet and flex head ratchet 1-3/4” wobble extension Universal socket adapter/swivel adapter 11mm socket Deep 11mm socket. Air ratchet to make quick work of spinning the nuts off. The subframe brace/bar is the only one I don’t know much on, since I cut it. Maybe if you loosen the right side of the subframe so it drops down a little, the manifold can clear the firewall and subframe.
e90yyc2426.50 |
02-15-2022, 08:44 AM | #17 |
Art Collector
2427
Rep 3,450
Serf27 Thanks! That’ll definitely help. I do have an electric ratchet which should help, but I’m sure it’ll still be awkward as hell.
I’d imagine once I’ve got them off it’ll be easier to see things? I’m planning on replacing all the studs, so I really hope I can see .
02-15-2022, 09:01 PM | #18 |
Rep 4,324
The electric ratchet will definitely help with the rear bolts where a ratchet Barry has enough space to turn 1/8” at a time.
The AC line I removed was the top one. Hopefully it isn’t an issue for you. I still have the XI here, so I took a photo of it. Plenty of room to change the studs with the manifold removed.
e90yyc2426.50 |
02-20-2022, 10:22 AM | #19 |
Art Collector
2427
Rep 3,450
Serf27 I started removing nuts last night just to see what I’m in for. Happy to say I was able to remove the ones around the AC hard line and the ones at the back near the firewall with relative ease. For the nuts around the AC line, I was able to seat the socket/extension by hand, and then pop the ratchet on..
Having just the right length deep socket/extension combo made all the difference. Shorter and I wouldn’t have cleared manifold with my ratchet; longer and the ratchet would have been pinned up against the body and unable to turn. I broke them loose by hand and then zipped them off with the electric ratchet. Would highly recommend the tool. The extended-reach head has come in handy more times than I can count. There might still be some surprises lurking but I feel pretty good about it. I’ll finish the job on Tuesday when they arrive.
