02-15-2022, 05:31 PM | #3 | |
Rep 425
xcelir8bmw415.50 |
08-08-2022, 10:02 PM | #11 | |
Rep 39
From previous thread:
05-12-2023, 10:23 PM | #13 |
Pip
26
Rep 43
Drives: 2023 BMW M240i xDrive
Mirror Tap Power Off
Does the mirror tap cut power after a while when car is turned off? I'm using a Uniden R3 wired to the mirror and I waited about 5 minutes and it didn't seem to power off
05-12-2023, 11:39 PM | #14 | |
Rep 1,559
I just power mine off manually when I pull into the alley, or elsewhere if I’m out of the car for awhile. I could disassemble and tap into the correct wire that cuts power with the ignition, but not motivated enough to do that. |
05-13-2023, 01:50 PM | #16 |
Rep 1,559
Sounds like you tapped into the correct wire, or at least a better choice than mine. Mine will stay one until the R8 times-out, or of course if I manually turn it off, which I do most of the time.
05-21-2023, 11:28 AM | #17 | |
Rep 795
Some things to note: power shuts off after 7 to 10 minutes of not using/waking the car. The power will be turned on if you do anything to wake the car. IE: unlock doors, open a door, pop the trunk, shut the hood, etc. |
