N52 Oil Catch Can
02-24-2022, 03:10 PM | #1 |
Rep 45
N52 Oil Catch Can
Has anyone done an oil catch can on an n52? I put in my 3 stage manifold the other day and found oil in my old manifold, as well as my throttle body. Any tips?
02-25-2022, 01:58 AM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
I fitted one to my N53 (kind of European equivalent to the N52). It's done a superb job of keep oil out of the engine (direct injection, so valve prone to carbon). I went with this make:
https://www.saikoumichi.com/
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
02-25-2022, 11:50 PM | #4 |
eBay Special
3108
Rep 3,038
Drives: E90 330xi
It's a really easy setup.
BMS Rep Catch Can A few feet of 3/4 line Either re-use your CCV connections or get an adapter from 3/4 to 1in 1in hose to 3/4 adapter or CCV connection -> 3/4 hose -> Catch Can -> 3/4 Hose -> Intake port on manifold (below small DISA)
Common sense is a flower that does not bloom in everyone's garden
02-26-2022, 01:44 AM | #5 | |
Rep 268
can you please share some photos of your OCC installation? Thanks |
02-26-2022, 02:18 AM | #6 |
Rep 3,200
Here you go:
StradaRedlands4995.50 |
02-26-2022, 02:41 AM | #7 | |
Rep 268
Thanks a lot |
02-26-2022, 03:37 AM | #8 |
Rep 3,200
You're welcome. One thing to bear in mind if you're thinking about this is to use reinforced hoses, as 'normal' hoses collapse over time due to heat and the PCV vacuum.
ornicar136.00 |
